Colour problem I have problem with my sharp 20R-SC, the colour turn yellow
  • 99 Answers
The problem in your TV.is in the color section.
one of the transistors or IC (integrated Circuit) on that section,is already defective or may be there is only a cold solder in that section,try to check it and solder it again or replace the parts with the same value.if you dont know how to do it ,
call a qualified technician or bring it to the Repair shop.
Posted on Feb 20, 2008
Ic c3789
Posted on May 24, 2012
My sharp mx2310u, yellow toner does not Aline with the other colours each time I print, a job the yellow does register
You have registration problem in that the yellow toner is not laying on top of the other colors, might check the sharp web site for operators manual and check to see if your model allow and operator not a service tech to run the registration procedure other wise have tech come out and check the copier he might also have firmware to re-flash the copiers operating system (Not computer driver, which you can normally get free from most copier companies, to update let say Windows 7 or 8.1 to windows ten 32.64 bit etc.. Or call Sharp customer service might have chat feature? ) which might correct a problem with the yellow toner/drum system.
Feb 02, 2016 | Sharp Office Equipment & Supplies
Master code for sharp tv
0404 is one code. If you wish to get more, check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 01, 2013 | Sharp 20R-S100 20" TV
The colour has orange and yellow tones I cant remove
Have you tried cleaning the screen? I smoke cigars, so I have to go around compressed-airing and wiping stuff down constantly. Screens look yellow/orange if I let it go too long.
Oct 19, 2012 | Hitachi 50C10 LCD TV
Yellow and Magenta do not register when I print colour jobs. Other colours register perfectly. What shall I do?
It seems your color cartridge have issue try changing the color cartridge or clean the head cartridge head and try.
Regards,
JJ
May 13, 2011 | Sharp AR-C260M All-In-One Printer
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
Lanier SC 363
check the td sensor it has a high reading.. if this is a colour machine check the yellow dev unit.. some times the gears jam and can cause errors it may need replacing
Aug 03, 2009 | Lanier Office Equipment & Supplies
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
Yellow box with the letter "K" in it.
the TV needs to be reset with the Factory Initialization. Try contacting Sharp at 1-800-327-4277 for instructions.
Sep 17, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
