Question about Gaggia Evolution Espresso Machine
Hi, Machine seems to drip a lot from the head when it's switched on a warming. I have changed the big round gasket and still no solution. Could it be the rubber valve behind the spring and nut in the head?
    President:
  • 1,618 Answers
Yes it is the rubber valve behind the spring, at some time there might have been excessive pressure buildup, most likely because of a fine grind, and that might have moved the valve slightly, check it for damage, and clean the small hole that it fits into and you should be good to go, if there is no damage to it.
Posted on Feb 03, 2010
Testimonial: "Good clear advice that fixed the problem"
Hyo gt650r 06 Noticed bike is always running hot after short rides. Checked coolant and no coolant keeped topping it up. Haven't noticed any coolant dripping so checked engine and oil is milky. What do I...
Take the head off and take it to a machine shop where they can check and adjust everything. cost is normally around 150 for the machine side and and get a upper gasket kit which includes the head gasket it's a lot better to do this than to just replace the head gasket and the plus side is you only have to take it apart once
Aug 28, 2014 | Motorcycles
I have a 98 uno turbo If the car idle it don't smoke when i drive of for a while there come white smoke out but not a lot but it look like it coming out with force beat of the motor cam and then the water...
It has a seeping head gasket! This is a common problem with all import engines. They are not designed to run hot! Even if they have a lot of miles on them, this problem always seem to follow. If you are familiar with running compression test on a engine, I highly suggest you run one on your engine. Run a compression test with it cold and after the engine is warmed up. If the compression is lower once the engine is warm, your head gasket is leaking compression, and its pulling oil from between the gasket into the cylinders causing the smoke. Or it can be a combination of a seeping head gasket and a bad oil seal on the turbo too as well....
Jan 28, 2014 | Cars & Trucks
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
Water is dripping from the head while using the steaming wand. It seems like a seal is bad--could that be the case?
first check the water supply which where is connected thru your machine and lastly the gasket which controlling volume of water thru your machine
Jan 08, 2011 | Solis Crema SL-90 Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
I want to change the head gasket but cannot remove it.
Hi
Remove the water tank and drip tray. Then turn the machine upside down. That way you can see the gasket. Stick you allen wrench into the hole the screws were in and pry the center out. Now you can get a screw driver under the gasket and pry it out. It might come out in pieces but that is OK. They get hard and that is why they won't seal. They should be replaced once a year to work good.
Jul 31, 2010 | Gaggia Classic Espresso Machine
I have a 1994 Olds Cutlass Supreme overheating
If it's the water pump, you should be able to see it dripping just behind the pulley. The seal on the water pump is usually what goes. If there is antifreeze drips all over the front of the engine, and it drips a bit after you shut it off, it likely is the water pump.
If it runs poorly when you first start it in the morning, however, you could still have a head gasket problem. If that is the case, you will see a lot of white exhaust, which is the cylinder blowing the antifreeze out. One thing you can do is run it with the rad cap off, and see if it continues to bubble. If it does, then your head gasket is leaking. I am assuming it is a V6, so keep in mind that you have 2 head gaskets. The other oine could be gone now if it wasn't replaced.
Apr 05, 2010 | 1994 Oldsmobile Cutlass Supreme
Rancilio Silvia leaks around group head. Gasket seems fine.
HI
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don't form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Oct 23, 2009 | Rancilio Silvia Espresso Machine
Coolant issue with 1997 blazer
check to see if you have a leak in your heater core,and if the heater core is not leaking you might have a leak on the intake gasket or the head gasket
Jan 03, 2009 | 1997 Chevrolet Blazer
Gaggia Evolution Espresso Machine Logo
478 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
