Question about Xerox WorkCentre XE80 Laser Printer
I have the xerox xe 80 and just changed the drum and toner and still have lighter output on my copies
Maybe the transfer corona is broken or humidity in paper
Posted on Feb 03, 2010
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
HI, MY XEROX 1045 COPIER has making ""clicking"" sound
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum.
Once you replace the drum, you need to reset the copier.
Nov 17, 2009 | Xerox Office Equipment & Supplies
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox 416P faded copies
Remove the glass and thoroughly clean the lamp, mirrors and lens. Also the glass on both sides. If that does not work, remove the toner and drum, look inside the machine for a small opening about 8 inches long and a quarter inch wide. That is the laser window. It may also need cleaned. It is possible the laser needs to be removed and cleaned.
I am not sure, can you print reports on the p model? If so make a printed page and tell me if they look fine.
What you have to remember on a digital copier is when the optics get dirty , the image gets lighter.
Mar 17, 2009 | Xerox WorkCentre Pro 416Pi All-In-One...
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
Copies are light color and l like to know how to get darker
MOst likely the drum cart is the issue. There is a fine charge wire and grid on top of that cartridge that probably is going bad.
Aug 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
How do I change the drum on a Sharp AR-M237?
Hi, i assume you have a drum to replace it with?. Can't really clean them as they are very sensitive. Why does it need changing, your copy quality is effected?. It is a faily straight forward procedure.
Let me Know
Andy
Mar 04, 2008 | Sharp AR-M237 Copier
Xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Feb 27, 2008 | Xerox 5305 Copier
Xerox WorkCentre XE80 Laser Printer Logo
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
