Question about Tissot T-Touch T33759851
Tissot T-Touch T33.7.788.51 Bracelet replacement
I need to order a replacement bracelet for a T-Touch Tee.7.788.51. The bracelet has broken on the second joint from the watch. I was able to remove the bracelet, but there appears no way to install a new pin or I have not found one that works. The watch is a Titanium Analog/Digital Mens watch.
  • 1 more comment
  • Anonymous Mar 26, 2008
    problem with pins
  • Anonymous Mar 16, 2014
    I need to know how to remove bracelet from case on men's Seiko Titanium watch.
  • Anonymous Mar 28, 2014
    0585
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
Posted on Mar 28, 2008
From where i can buy a bracelet for Tissot PR 50.
mcdevito75 here, Ebay is a great place for your Tissot watch band, or you can check with any small watch repair shop in your area, specially if you want a band directly from Tissot.
Oct 26, 2010 | Tissot PR50 Titanium Large Bracelet Watch...
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: I like it so much, ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Guest,
Please feel free to browse above link for the prices of your dream watch.
Thank you.
May 18, 2010 | Tissot T Touch Stainlesssteel Watch
Watches T Touch Stainlesssteel case and bracelet sapphire crystal 30m water resistant men watch Watch for Men: Very interesting sites., ...
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Please feel free to browse above link for your desired watches.
Thank you.
May 17, 2010 | Tissot T Touch Stainlesssteel Watch
My gunmetal titanium band (only half of the band is broken, what do I need to get it repaired or replaced???
some watches provides bracelet parts to replace, like rado, tissot etc...otherwise you have to replace whole bracelet, as per my experience titanium cant be solder nor repair
Feb 23, 2010 | Skagen Signature Mesh watch
Tissot Seastar 1000 Does anyone know of a source
Tissot is Swatch. They do not sell parts! You need to contact the company OR where you purchased the watch.
http://www.tissot.ch/?mod=stores&action=search&search=&regions=2&countries=195&countryregions=&option=cs
Jan 14, 2010 | Tissot Diver Seastar 1000 Auto Steel Large...
Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Jan 04, 2009 | Tissot Le Locle Automatic Chrono Large...
Bracelet
srevice center for tissot watches here in the philippines is only at timeline...g/f farmers plaza cubao,q.c. its fronting gateway and araneta coliseum.
Jul 29, 2008 | Tissot T-Touch T33759851
Tissot stainles steel bracelet
you should take it to a qualified jeweler
Oct 14, 2007 | Tissot (T60128232) Wrist Watch
Tissot T-Touch T33759851 Logo
1,923 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
