Question about Visioneer PrimaScan Colorado 2600u Flatbed Scanner
The computer suddenly can't find my scanner. Usually it just shows icon under My Computer but today it has disappeared! Tried testing plugs and USB's and restarted pc twice. STill not showing up. Please tell me what I can do. No disk available to reload
    President:
  • 1,738 Answers
Click on these links for your Windows 98/ME/2000/XP drivers and manual. Visioneer PrimaScan Colorado 2600u:
Drivers PrimaScan Colorado 2600u
2600 User Guide
If you found this information helpful, please give me a big thumbs-up when you rate my answer.
Posted on Feb 03, 2010
Jeep cranks but does not start
Hi, First replace your plugs. Second check ignition coil(s) one maybe bad. replace with new. If all else is good, have your mechanic check the computer codes. (code scanner) Many of todays cars and trucks have computers to run and control the engine. (management system). Good luck
Feb 04, 2015 | 2004 Jeep Liberty
My scanner used to work just fine, but suddenly it won't work anymore. It is plugged in and everything, but suddenly in Photoshop, the Xerox 7600 option under File > Import disappeared, and the WIA...
Have you tried an other USB cable??? have you tried a different USB port on the computer??? try the scanner on an other computer as well, does it have POWER???... eazy stepps to troubleshoot all types of devices is to first make sure the device has POWER, than concentrate on connectivity (cables, ports, etc...) than try it on an other computer, re-install drivers as well..., check for viruses also, when everything is clean and it still not working than replace the device... it's dead (send flowers) ha! just kidding!
Jul 23, 2011 | Xerox 7600 Flatbed Scanner
When I plug the camera up to the computer to put pictures off it onto the computer nothing comes up
hi, if your using windows and have the camera plugged into the computer via usb lead then you need to open my computer then you should see it listed under removable media devices.
Let me know how you get on or if you need further assistance ok.
if it dont show up then try plugging it into another usb port and try again
Nov 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Problem installing USB to serial port connector/brifge
When an USB drive makes problem on one computer only then an updated mainboard/chipset driver may help.
If it doesn't help then it may be just incompatible with the computer's USB ports - that's not unusual. Therefore it's helpful to have an additional USB PCI card as alternative in the computer, best with NEC chip.
Cheap USB extension cables may cause problems too. The thinner and longer the higher the risk for problems. The plugs wear out in time.
USB ports on front of the computer are more problematic because the USB is leaded by a cable thru the computer case which is full of interferences. Furthermore the port a mechanically stressed, so the usually fail sooner or later.
Other attached USB devices may interfere, usually such ones that don't use a default Windows driver and which permanently transfer data, such as web cams.
Cheap USB hubs die slowly. First symptoms are disappearing devices and communication freezes.
If an USB device has been detected as 'unknown device' once it might be necessary to delete it in the device manager and replug it then.
Another try is a complete USB device clearing by Microsoft DEVCON and the RenewUSB.bat from http://www.robvanderwoude.com/devcon.html
A cleanup can be done manually too. Put the following two lines into Notepad and save them as DevManager.CMD:
set DEVMGR_SHOW_NONPRESENT_DEVICES=1
devmgmt.msc
Started thru this DevManager.CMD the Windows device manager shows non present devices too if you check "View" -> "Show hidden devices". Under "Disk drives", devices shown with a light gray icon are non present. Just delete them. Same procedure under "Storage volumes". There may be a lot of them...
My commandline tool DriveCleanup does it for all currently non present storage volumes and USB drives.
Microsoft has set up a page for General USB troubleshooting in Windows XP
To have DEVMGR_SHOW_NONPRESENT_DEVICES=1 set permanently, download and doubleclick this file: DevMgr_Show_1.reg. After next logon it takes effect.
It also sets DEVMGR_SHOW_DETAILS=1 to get the "Details" tab in the device's properies dialog under XP.
Thanks For Using Fixya
Sep 10, 2009 | Computers & Internet
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Scanner suddenly disappeared from the Applications folders.
First unplug scanner, turn off mac, remove mac battery and unplug adapter, plug everything back , restart and reconnect.
If that did not work, then do the following:
Unplug scanner usb and reinstall scanner/printer software again on your MAC.
Oct 14, 2008 | Canon MP970 Photo All-In-One InkJet...
Problems with v350
HI-
Try to reseat or unplug and replug the usb cable for the scanner to your mac, errors indicating that the computer is not communicating with it. you can also go to apple icon then go to system prefences or system profiler, click on hardware then USB check if there is an epson scanner under USB device tree
keep me posted
Sep 08, 2008 | Epson Perfection V350 Flatbed Scanner
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Hp vga webcam
Green light is on mine, but USB port shows no device. When I plug it in, I get "found new device" message, but no icon on my desktop. None of my messengers recognize it either. It does show up in cameras and scanners though...I'm so confused.
Apr 01, 2008 | HP VGA Webcam
Visioneer PrimaScan Colorado 2600u Flatbed Scanner Logo
255 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Jeff Hogancamp
Jeff Hogancamp
Cosma Papouis
Cosma Papouis
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
