Question about Sharp UX 355L Plain Paper Thermal transfer Fax
Phone can not get adail tone on phone, checked line, every things ok the words on telephone screen says ''on hook dail'' checked all lines, phone with no dial tone. Thus unable to fax anything.The book states need service. Where? I am in Washing,DC. Need repair shop list. Thanks EAM
  • Xams Feb 21, 2008
    No solution as yet. Phone from wall was pllugged in Line. No dial tone yet EAM
    Master:
  • 788 Answers
Plug a regular phone into the jack, is there a dial tone?
Reset your fax machine, unplug it from the wall, wait two minutes, plug it back in.
Posted on Feb 21, 2008
  • Dean Joly
    Dean Joly Feb 21, 2008
    Also make sure your cables are plugged into the proper jacks. The cable from the wall goes into the line jack.
  • Dean Joly
    Is there a dial tone with a regular phone plugged into that jack? If the jack doesn't work you may need to have your telco take a look. It may not be the fax machine that has the problem.
  • Sharp Master
  • 19,396 Answers
Hello, I will try to help you.
  • 1 more comment
  • Ginko
    Ginko Feb 21, 2008
    To start here you can find service mual for your unit.
  • Ginko
    Ginko Feb 21, 2008
    Using the following link You can email Sharp Usa to find out the nearest service shop.
    http://www.sharpusa.com/global/ContactUs...
  • Ginko
    Ginko Feb 21, 2008
    And here comes their mailing address and phone number:
    Sharp Electronics Corporation
    Sharp Plaza
    Mahwah, New Jersey 07430
    Telephone Numbers:
    Customer Assistance Center
    1-800-BE-SHARP (1-800-237-4277)
    Corporate Headquarters
    (201) 529-8200
    If this solution had been helpful, dont forget to rate. If you need further help please ask us.
    Regards
    Sergeant:
    Champion:
  • 317 Answers
WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
ERROR T82 BIZHUBC280 IMPOSSIBLE TO SEND OR RECEIVE FAX
Check your fax line connection is the FAX line plugged into the Line jack on the copier and NOT THE TELE connector. Must be Line. Take a old phone like a old princess phone and hook it up to the wall get a good dial tone call some one any noise? Have some one call the fax number OK if hooked to the copier get the tradition noise of a fax line, Check the fax line itself use only one with two wires not four, black and yellow only no red and green. Also put on one of the EMI devices on the cable going into the copier cut down on electrical noise. Line can not be digital must be all analog (POT) Plain Old Telephone, have your phone provider check the line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 18, 2010 | Minolta Office Equipment & Supplies
Can not get a dial tone. Phone appears to be off the hook. How do I trouble shoot it?
Unplug the phone line from the fax machine. Wait at least 1 minute then call the phone number that goes to the fax machine from another line such as a cell phone. Make sure you get a ring and not a busy signal. If you get a ring then hang up the phone. Plug in the fax machine again and call the fax number again. If you get a busy signal then either your phone if off the hook, the switch that is actuated when the phone is placed in the cradle is bad or your modem in the fax machine itself has gone bad. Another thing to try is unplug the fax machines power cord for 30 seconds then plug it back in. I have seen the modems get "locked up" and keep the phone line open. Unplugging will sometimes reset this and get it working again.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
No dail tone --but phone line is connected
Hello.
If the dial tone is not heard check the volume. It may have accidentally been muted or turned down.
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone? It could be that the phone line plugged into the surge was loose.
Try a different phone plug, outlet.
If the other phones on that line work OK, disconnect all the phones connected to the line, leave them all disconnected for 3 minutes, and then connect one at a time.
If still a problem and the other phones on that line work OK, give this a try:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two. That way you can get more of an idea of whether your phone will work. After an hour or two, plug in everything.
Hope this helps.
Jan 04, 2010 | Uniden 2.4 GHz Expandable Phone System...
HP officejet all-in-one...keeps saying phone is off of the hook and will not give me a dial tone to fax. Is there a particular setting I need to check ?????
The very first thing to check with a fax machine is that the line itself is OK. The possibilities are much greater that there is a problem with the LINE and not the HP itself.
Hook up a regular telephone to the fax line, disconnecting anything else that may be on the line. If the telephone doesn't have a dial tone, call the phone company. If you DO have a dial tone, then maker sure that the phone line is connected to the correct port on the HP. There are two, usually. One is for the LINE and the other is for an EXTENSION (a phone that is daisy chained off the fax machine). If you have the LINE connected to the EXT port, it may give you this error.
If you have multiple items connected to the same phone line, try removing all of them but one regular phone, and see if you have a dial tone. If so, add the other items back, checking for a dial tone after each one. If one of them causes a lack of dial tone, replace or repair it.
The phone company may tell you that the problem lies in your inside wiring. I have seen that before. You can take your phone out to the telephone service box on the outside of the building. These usually have regular phone jacks in them. Disconnect the jack wire that runs into your house, and connect the regular telephone into the box itself. If you have a dial tone, then there is indeed a problem with the wiring in your building.
Jul 16, 2009 | HP Office Equipment & Supplies
Samsung 816 power outage dailing an outside line
First thing you should verify a dial tone on the fax machine. (use any analog phone)
If you have dial tone, press 9 and then a number
Second is it conected through tel. system? (did it have an internal extension) and there is no dial tone then your analog port may be fried. Call your telephone vendor. He should be able to help you.
You can purchase a manual for about 10 dollars
Email your system model number to sales at aaa-avad.com for further instructions
Mar 31, 2009 | Samsung Prostar 816 Phone
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Home phone
my phone has a dial tone but wont dial out or recieve calls.
Sep 23, 2008 | Motorola Mobility AT&T Prepaid Free2Go...
Phone
Make sure the phone cord from the wall is plugged into the outlet on the machine marked LINE and not PHONE.
Dec 28, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Open Questions:
Sharp UX 355L Plain Paper Thermal transfer Fax Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
