Main burner is not igniting , can see a spark but cannot tell if it is strong enough
  • t_edison02 Feb 03, 2010
    Over the 3 tries, the first try the spark appears strong but of short duration, the second and third try is very weak. Does this point to a bad cable?
    Thanks!
  • Ken Bledsoe May 11, 2010
    The spark you are seeing is for the pilot light. Now if that is failing to light the gas valve might be bad. Not opening the pilot valve for the pilot flame. If you have a volt ohm meter you can tell but at this point would recommend getting a tech in to find the cause.
  • 1,420 Answers
You may have a plugged pilot line or orifice. Find your gas valve and make sure it is in the "ON" position. If it is, turn it to off. Remove the nut holding the aluminum pilot tube on and inject a stream of air into the line from one of those can of air. Reassemble the pilot line and spray the can of air on the pilot assembly. This hopefully will remove any blockage that may be effecting the gas flow to the pilot.
Posted on Feb 03, 2010
Testimonial: "Your input was helpful. Thanks"
  • Chandler Ede
    Chandler Ede Feb 05, 2010
    If the spark is getting continually weaker each try, the logical culprit is the ignition box. It would be a good idea to inspect the spark wire for a good connection and also any ground wire that is coming off the spark module going to ground. Unscrew the screw holding the wire to ground and sand it a little then reattach.
Main burner ignites and goes right back off
then the thermocouple is not telling the main burner it is able to light . pilot flame might be too small or not close enough to set it to light .
Nov 05, 2015 | Heating & Cooling
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Siemans xtronic Cual-Fuel Convenction Range: burners take a very long time to light using the automatic ignition. Clicks for up to 1 minute. every once in awhile it will just light quickly. Burners are...
Might they be too clean? Is it possible that you have soap/food/grease buildup on the ignition points? It sounds like your spark is not strong enough to light the gas.
May 02, 2011 | Siemens HD2515U Stainless Steel Dual Fuel...
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here: http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
Aug 10, 2010 | Hayward H400 High Wind Stack
Burner will not light
possibly the ignitor has a weak spark its making the jump to the burner but not strong enough to lite the gas did you check the lines for spider webs or other insects?
Jun 17, 2009 | DCS BGA27-BQ (NG) Grill
One burner does not light up. The ignition is clicking and providing sparks, and there seems to be plenty of gas. It works fine when i put a match to it.
Hi!
Make sure the burner cap or burner head is in place correctly, and that the jet or hole(s) for the ignition are clean of debris. In most cases like this, if there is spark present and no ignition, it means something is either clogged and dirty or the spark is not strong enough due to poor grounding.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool gas range
You may have a bad spark/ignition module, it is located under the main top (on most models) and tells the burners too spark
Jul 25, 2008 | Whirlpool Kitchen Ranges
Bought a hot shot universal fit ignitor
Typically, these units attach so that the spark gap is near any of the burner perforations. It is then wired back to the ignition unit. The burner must be chassis grounded for this to work, as much the ignition unit.
Mar 14, 2008 | Kenmore 463845504 Grill
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
