Question about Equator EZ 3612 CEE Front Load Washer/Dryer
No Power Lights are Out
I've used my Equator for a couple of years with no problems. Last week it died. No lights at all. The door switch seemed to be faulty so I replaced it.Still no power. Is there a fuse or rest button somewhere?
Is there a common cause for the machint to just stop getting power?
I've checked the power cord and 120VAC is getting to the machine.
There was no warning sign. Everything was wroking fine, and then, kaput!
Please help me figure out where to look.
Thanks,
Victor
  • Victor44 Feb 21, 2008
    The suggestion I got from an expert here is that the problem is the thermostat.
    I ordered a new thermostat but Steve, at Equator, doubted the fix. He walked me through a multi-meter test of the power source and found that there is power to the curcuit board from the capacitor. The problem is, the Curcuit Board is burned out.
    So when there is no power to the front lights, suspect the curcuit board.
    New curcuit board $260. New EPROM for curcuit board $28
    Anyone know a better place to find a curcuit board?
    Thanks
    Victor
  • 796 Answers
Hello
Posted on Feb 19, 2008
My 1996 plymouth voyager started to show short when I open either door. Heard clicking earlier when used left tyrn signal. Sounds seems to come from below junction block but I cannot see sparks or wor
There is a wiring harness that feeds to the door, electric door locks and windows draw a lot of amperage. Try removing fuses one at a time that supply power to your door controls until you see the problem go away. If that doesn't work, try other fuses to accessories like interior lights. If your headlights are dimming you have a power wire shorting to another circuit, if it were to ground it would blow a fuse.
Apr 30, 2017 | 1996 Plymouth Voyager
Battery light on followed by other lights then died
check the wire from alternator to the battery and make sure its not loose on alternator. happened to me a few years ago, forgot to tighten wire to alternator. car lights on dash came on and car quit while driving. just make sure you are getting at least 14 volts at battery while its running, good-day !
Oct 26, 2011 | 2006 Dodge Grand Caravan
My subaru impreza 2.0 turbo AWD engine has cut out 3 time in the last couple of weeks! the engine just dies no warning lights come on and after a while it restarts as if nothing wrong! no unusual noises...
Could be an air flow fault, check all your air pipes for holes or splits and also check the air flow meter and sensor. just clean them up before going any further.
Also check the earth lead from the battery to the slam panel, and to the gearbox make sure all the earths have a good contact to the car body.
Jan 22, 2010 | 2000 Subaru Impreza
My dome, footlamp and door lights fail to go off after 28 seconds. They do not fade off they stay on and flicker until I guess the battery would soon die. The car is a 2002 Impala. Started last week with...
check the door close indicator swithch located on the lower part of the door.. the one that indicates if the door is closed properly, maybe one of them is busted...
Jul 19, 2009 | 2002 Chevrolet Impala
Battery died after experancing power door didn't close fully...
if you turn off the switch for the interior lights,an override,it will prevent the battery from going dead until you can get the door alignment or switch repaired.the interior lights,there is more than 5 will kill the battery for sure.
May 23, 2009 | 2003 Chevrolet Venture Passanger
Maytag Dishwasher flashing lights
I have the same problem with the lights flashing on the control panel. It pops up every 4 or 5 months. The only solution I have found is to press the delay/resume button one time then press the drain/off button twice. You may have to hold the keys down for a couple of seconds. This seems to reset something in the panel. Make sure you haven't pressed the 3 second lock button or it won't work.
Mar 17, 2008 | Maytag MDB7100AWB Dishwasher
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
66 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
