Question about Microwave Ovens
I have a EP2000 Potterton Programmer which has developed a continuous humming noise. The central heating light flickers, whilst the hot water light remains stable. Can you advise the possible cause for this humming noise which has just developed. The programmer is only 2 yrs old. Thank you.
  • johnwgarrett Feb 10, 2010
    Typically, when I went round to investigate the humming noise it did not happen. However, thanks for your suggestion to the problem. Should it occur again I will attempt to use your advice. Thank you.
  • 3,230 Answers
Well first of all you can please follow the below steps -
1. Set the programmer to CH on, HW off.
2. Turn the room thermostat right down.
3. Measure the voltage between N and the terminal marked SwL on the mains terminal block of the boiler (should be AC 0V).
4. Continue to measure this voltage and turn the room thermostat right up (there may be an audible click at the thermostat as it changes state). As the thermostat demands heat, the SwL voltage at the boiler should switch to AC 240V.
5. Set programmer to CH off, HW on and repeat 2 to 4 with HW thermostat.
Please post comments for more help or information.....
Good Luck!!
Thanks
Posted on Feb 03, 2010
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Microwave will not heat, but will turn on. Clock and Timer still work. Turntable turns. Making a loud humming noise and light flickers
This clearly indicates a bad magnetron, "heats food" in most cases it is cheaper to replace the microwave oven than have it repaired, since the magnetron is the heart of the unit.
Mar 01, 2012 | Microwave Ovens
Microwave worked this morning and now not.....made no noise just stopped heating.
HELLO.
The solution is to diagnose the magnetron as explained below.
* 1 Fill a mug with room temperature water from your kitchen sink.
* 2 Place the mug of water on the glass cooking plate inside the microwave.
* 3 Set the microwave on "High" for one minute and press "Start." You should hear the magnetron hum while it is working.
* 4 Remove the mug carefully from the oven by its handle. The magnetron is working properly if the water is hot or warm. The next step repair or a replacement of magnetron if the water is still cold.
Thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
MY ROPER MICROWAVE NOT GETTING HOT
Hi and welcome to FixYa, I am Kelly
When everything but the heat works there are 2 common components that fail. The high voltge capacitor or the high voltage diode. In rare cases the magnetron fails because the oscillator in the top of the magnetron sticks. When the oscillator sticks the magnetron makes a LOUD humming sound and you do not get heat. However.... a open diode or shorted capacitor will make the exact same sound briefly before the main in line / internal fuse fails.
The capacitor and diode are items 4 and 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504310&diagram_id=28243249#d28243249
NOTE: Before doing ANY maintenence you must hold an plastic handle screwdriver back on the handle and ground the capacitor terminals at least 3 times. (Just in case it has not failed.)
Failure to do so will ruin your day and pass along one heck of a shock.
To check the diode you must disconnect one terminal first. The read it with a meter. Reverse the leads and check continuity again. It should read continuity in ONE direction / polarity only. Id should NOT read open both ways or shorted both ways.
To check the capacitor you have to remove all the terminals from ONE side of the capacitor terminals. With the meter on R X 10,000 probe the 2 terminals. You should see a brief jump in resistaqnce and then the meter drifts to infinty. Reverse the leads and do this again. You must get the same jump in resistance and then the meter drifts to infinity. If it does not do this it has failed and must be replaced.
If both the diode and the capacitor pass the checks above the next step is to check the magnetron for continuity across the 2 terminals. It must read continuity. Even if this test passes the oscillator can be stuck and it will not heat. (Again if it is stuck it will make a LOUD humming noise.) It is not repairable.
I suspect you either have a bad diode (most probable cause) or bad capacitor (2nd most probable cause).
Thanks for choosing FixYa,
Kelly
Jul 03, 2011 | Roper MHE14XKB Microwave Oven
Microwave lights up plate turns something hums inside but the inside of the microwave never produces heat.
Sounds pretty normal but the inside is not supposed to get hot - only the food is.
Try heating a half glass of water for 1 minute if it gets hot... its working - if not then the actual microwave generating device inside has probably died.
In that case buy a new microwave oven as the cost of parts and labour to repair is usually more than cost of buying a new one.,
Jun 09, 2010 | Maytag MMV1153A Microwave Oven
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Microwave doesn't heat up
There are three solutions (source) =>
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Dec 31, 2008 | Microwave Ovens
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
