Question about Gestetner DSm618 All-In-One Printer
Hi i have an Gestetner DSm618 All-In-One Printer. However their is no option on the control panel to config the network setting. their is a nic card put i cannot see the network settings
Network interface. printer and scanner didn't work.
these are not devices that just anyone can install you have to know what you are doing and have the correct software because their different ways to configure these devices depending on environment and requirement please contact your service provider as they are suppose to set up the device for you or other wise contact your nearest RICOH dealership for support
Nov 23, 2010 | Gestetner DSm618 All-In-One Printer
I need drivers for gestetner dsm618
Hi, you can download the DSM618 drivers here:
http://support.aficio.com/bb/html/dr_ut_e/ges/model/x2015_18/x2015_18en.htm
Just pick your operating system and the specific driver(s) you want to download!
Aug 20, 2010 | Gestetner DSm618 All-In-One Printer
How do you install an ethernet card on a gestetner DSM645 copier/
Are you trying to install an ethernet or "NIC" card in order to turn the machine into a printer? If so then you need more than a nic card. You would also need a ROM chip, Print controller, Hard Disk Drive and the buttons for the control panel.
If you are just replacing a NIC and expanding the memory then that is possible but the instructions to do so would be more than could be typed up here.
Jan 16, 2010 | Gestetner DSm645 Digital Imaging System
Do you know where i can get a ethernet card for a dsm645 cheap or used?
Does you machine currently have the print option and the NIC has just gone bad or are you wanting to add print?
If your NIC is bad keep in mind this machine is the same as Ricoh 2045 or a Savin 4045. You will need to pay close attention to whether you have a 645SP or a 645ESP. The Print Controllers/NIC's are different for the E series.
Just search Ebay or Google for the Ricoh/Savin models and you cand find them. I just bought and installed one from Ebay for a customer last month($200).
If you don't currently have print then you need more than just the NIC card. You will need the Hard Drive, Controller, Chip, and control panel buttons.
Dec 03, 2009 | Gestetner DSm645 Digital Imaging System
Gestetner DSM616 no network config
Sounds like you don't have a print or print/scan option in stalled. All machines come with network port but only works if option is intalled. You can check if you have the option installed, maybe just not activated. At the back just abouve the network port there is a cover that covers 2 sd card slots. If the is no sd card installed you will not be able to print to the machine. If the is a sd card installed contact me again and i will help with activation
Mar 24, 2009 | Gestetner DSm616 Printer
Use X3470 with print server
MOST OF THE TIME AND I MEAN 90% OF THE TIME IT IS THE CABLING AND CONNECTOR ARE THE PROBLEM AND THAT IS EASY TO FIX.
SOFTWARE ISSUES ARE EVEN HARDER TO SOLVE BUT BEFORE I SEND YOU DOWN THAT WAY HERE ARE SOME OPTIONS TO INVESTAGATE BEFORE MAKING ANY TYPE OF SOFTWARE CODE CHAGING. TRY THE FOLLOWING OPTIONS FIRST...............:
1 CHECK EACH COMPUTER BY GOING INTO CONTROL PANEL OPEN FOLDER CALLED NETWORKING AND SHARING CENTER.
2. NIC CARD INSTALLED IN THE COMPUTER AND GO TO DEVICE MANAGER AND TEST THE CARD, UPDATE THE DRIVERS AND MAKE SURE EVERY THING IS WORKING PROPERLY.
3. IF THE NIC CARDS ARE CONSIDERED A PLUG AND PLAY DEVICE YOU CAN GO TO
SYNC CENTER AND IT WILL CHECK EVERYTHING AND TEST THE EQUIPMENT FOR YOU, LIKW WIZERD WOULD DO.
4. GO TO SECURITY CENTER AND MAKE SURE THERE IS NO CONFLICKS WITH ANTI-VIRUS PROGRAMS *****************
ON ALL THE COMPUTERS YOU ARE HAVING NIC ISSUES ONLY************************
5. CONTROL PANEL OPEN UP WINDOWS DEFENDER CHECK FOR ANY TYPE OF MARKS THAT SHOULD NOT BE THERE, YOU ONLY WANT xxxxxxxxxxxxxGREEN -MARKS******* IN THESE IMPORTANT AREAS
6. GO INTO CONTROL PANEL AND OPEN FIREWALL, THE FIREWALL ONLY GREEN IN THIS AREA TOO.
NO YELLOW, ORANGE, RED MARKS.
IF YOU FIND ANY ERRORS CLICK ON THE ERROR AND GO ON LINE IF YOU CAN TO RESOLVE THE ISSUES BECAUSE THEY ARE GOING TO USE EVERY VENDER OUT THERE TO RESOLVE THE ISSUES WITH YOUR SYSTEMS.
7. FIND A KNOWN NIC CARD THAT WORKS AND CHECK EACH COMPUTER AND GET IT TO WORK THAN SET THE CARD UP TO THE SETTING OF THE CARD AS THE SAME AS THE TEST CARD IS SET TO. *********** I KNOW EACH NIC CARD HAS TO HAVE ITS OWN CODE IN ORDER TO WORK PROPERLY,..USE THE HIGH NUMBERS SO YOU WILL NOT HAVE ALOT OF ISSUES AND EERORS WITH YOUR NETWORK.
8. LAST THING CALL IN A NETWORK SPECAILIST OR ADMINSTATOR OF THE NETWORK.
I HOPE I HELPED YOU
RODGANDYSR
Mar 07, 2009 | Lexmark X3470 All-In-One InkJet Printer
Scanner driver
you can download the driver from www.gestetner.co.za
May 24, 2008 | Gestetner DSm618 All-In-One Printer
Scanning photos from DSm618
No, it will not show up there. It can scan two different ways. One is the scan router program installed on your computer. The other is scan to folder via SMB. It merely is a path back to a folder.
If you go into:
user tools, system settings, administrator tools, and address book management. The settings will be in there.
You could also "web" into your machine using IE and the IP address. Login as "admin" leave password blank. Go to the address book. Email me if you need further info.
Mar 22, 2008 | Gestetner DSm618 All-In-One Printer
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
Dec 27, 2007 | Gestetner DSm618 All-In-One Printer
Gestetner DSm618 All-In-One Printer Logo
144 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
