Question about Refrigerators
My Whirlpool side by side is not functioning properly. The freezer temperature varies from zero to 50 degrees all on it's own. One day things stay frozen, they next they are thawed, etc. It's sporadic. This is on the coldest dial setting. The referigerator side varies from 30-40 degrees, (not sure if that is normal)?
  • 52 Answers
Sounds like the thermostat is defective.
Posted on Feb 04, 2010
Freeze temp is not holding zero
When the compressor shuts off the freezer temps will slowly go up until the compressor recycles. The temp will not stay at a constant zero but fluctuate back and forth in accordance with compressor function. My temps vary from -2 degrees to about +4 degrees when the compressor kicks on again.
Nov 27, 2013 | GE Refrigerators
Freezer is icing up we have already vacuumed the vents in teh front and the back of the refridge and it is still icing up
Hello, This is a common problem, the first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35-42 degrees.Here are some things to try:
  • If your refrigerator temperature is closer to 25 degree try turning the temperature up slightly.
  • If you find the temperature varies a lot from the top shelf to the bottom(where it is coldest) try putting produce or other sensitive product on a higher shelf
  • If the temperature is too low and you cant make it warmer by adjusting the thermostats, you probably have a defective thermostat. If so you need to replace it because they cannot be repaired. Other possible problems are a leak in the seal(refrigerant) system, cold air migration(in side by side models) or a defective air damper.
Thanks
Jun 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
New upright kenmore freezer temp varies +/- 10 degrees
Over what period of time did this variation occur?
The freezer should have an automatic defrost cycle. The temperature will rise while it is going through this cycle.
Oct 18, 2009 | Freezers
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
