Maytag top load washer Mod# MTW5640TQ1 Won't spin on certian settings but will on others, timer won't advance on certian settings but will on others. Replaced timer twice. Also noticed this is a very loud machine!
  • Jerry Kerns Feb 04, 2010
    Thank You! Very helpful!
  • Jerry Kerns Feb 16, 2010
    I replaced the lid switch, no change. Same problem.
  • 10,515 Answers
I guess Lid Switch is Bad. The washer might not go into Rinse or Spin, if the Lid Switch is Bad for Safety Reasons.
More about Lid Switch :-
http://www.appliance-repair-it.com/Maytag-washer.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag neptunefront load won,t spin mod mle2000ayw
Hi Vinod, the lock light is not on. The motor and belt seem okay; it agitates. I think lock light is supposed to come on only when tub is full. Again my manual says nothing on this!!
Sep 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
