Question about Xerox Phaser 6250DP Laser Printer
Paper jams we have xerox phaser 6250dp. It gets jams at the registration roller. what is the fix for this?
  • 2 more comments
  • fix it fast Feb 20, 2008
    We have 2 of these printers doing the same thing. I did check to see if there was anything stopping the paper. Nothing.
    It is an intermitant problem, so I cant quite tell if the reg. rollers
    are turning or not. When it jams it does make a sort of buzzing
    sound just before it feeds the paper, that i dont hear when it works.
  • I just serviced a customer's printer today that seems to have the same problem. They say it occurs usually on the first page after the printer has been sitting awhile. I saw it fail once and it did make a funny noise, higher pitch, than the usual pre-print noises.
    I would guess that the feed clutch may have engaged too soon or the registration clutch is failing. Does anyone know which and what the part numbers of these clutches are?
  • Anonymous Mar 12, 2014
    Xerox Phaser 7760DN registration problem
  • 86 Answers
Check to see if there is anything stopping the paper like a small piece of paper/paperclip.
Also see if the reg rollers are turning.
I DO HAVE A FULL SERVICE MANUAL FOR THIS MACHINE ON DISK AVAILABLE
try the top 2 things if you still have the problem please get back to me.
Thank You
Posted on Feb 19, 2008
  • philip davies Feb 20, 2008
    First clean the paper pick up and feed rollers.
    Then clean the reg rollers and check the connections of the reg clutch.
    If the problem persists.
    Replace the reg clutch
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
Same Xerox 6250 whine and paper jam
Search xerox.com or tektronix.com for 6250FMSFix.psx, which is the driver to fix the fuser stall problem. When we downloaded the file 4 years ago, there was no link to the correct page. We had to do a google search on the site to find it. Other key words you might look for are "fuser", "stall", and "snippet". There is a FuserReadme.txt file that goes with this. It tells you how to put the file into the printer with ftp (that sounds safe; you did change the administrator password, didn't you?).
Jun 03, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
May 19, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox 6250 - Jam at Registration Roller
Are the tabs in those D shaped rollers broke?
They will snap off into the shaft, but still be on the shaft. Not uncommon.
reach in and hold the steel shaft with one hand and see of those rollers spin freely. If so the plastic pins inside the roller have broken. It is not uncommon on that machine. Pop one off and see if there is a plastic pin inside the roller.
May 02, 2008 | Xerox Phaser 6250DP Laser Printer
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP sensor not cleaning
Is there a specific code coming up? That can make it easier to pinpoint the exact problem.
Apr 19, 2008 | Xerox Phaser 6250DP Laser Printer
Jams at registration roller!!
Jams at the registration roll often come from one of the pickup rollers breaking a pin that keeps them in place on the feed shaft. They are D shaped rollers about midway back when you remove the tray.
They will be stopped in different positions.
Online at Xerox.com there is a complete parts list under support and drivers.
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
334 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
