Question about Zanussi Ovens
I need a new Grill Element for my Zanussi Built in double oven, Model no is FM5232
  • Zanussi Master
  • 3,463 Answers
If you are in the u/k,then I suggest you go to the zanussi web site,
WWW.SERVICEFORCE.CO.UK
Altrnatively, you could try a local deaer,whoo repairs cookers etc, they often have these sort of parts in stock.
Posted on Feb 03, 2010
The grill on Zanussi FM9232 keeps blowing the main fuse
the grill element needs replaceing or you have a wire on the grill element thats come off and touching down to earth
Sep 07, 2011 | Zanussi ZHQ575 Electric Double Oven
Zanussi built in oven and grill the element has gone but dont know how to get element out to replace any ideas thanks
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
Apr 11, 2010 | Zanussi ZBF360X Electric Single Oven
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
The element on my grill inside the oven is not heating up?
There are two possibilities of what is wrong here.
One is that the grill element has failed and may need to be replaced.
Second it could be a failure in the grill element control circuit (in effect the temperature regulator) thus not allowing power to the element.
Most likely it will be the grill element.
You would need to test with a multimeter to determine which a) by checking the resistance reading of the element and then b) the continuity of the control circuit.
Jan 20, 2010 | Zanussi ZHQ575 Electric Double Oven
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Grill not working
Yes, you will need to replace the whole element.
Dec 07, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
199 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
