Question about HTC G1 Smartphone
My htc mobile phone is time to time switch off
How can i switch off data on my HTC phone ?
  • On most Android phones (ICS, JB, KK): go to Settings -> Data Usage -> Data Connection -> Slide the switch on off
  • On some HTC phone: use the Data Connection widget
  • On some Android phones (1.5 - 2.3): go to Settings -> Mobile Networks -> uncheck Data Connection
Other ways:
How to Turn Off and Disable Mobile Data Connection 2G GPRS Edge 3G on...
How to Disable Mobile Data Usage Beginners Guide
Enable or Disable Mobile Data Android 4
How to disable the internet connection on your smartphone turn off your...
Aug 25, 2014 | HTC Magic Cell Phone
How to htc hd7 emergency turns off
There are two ways to turn off emergency
1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your phone means definitely your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your HTC HD7 phone visit MobileUnlockSolutions.com I hope it will be very useful to you.
Apr 17, 2014 | HTC HD7 Cell Phone
UNLOCK CODE FOR SAMSUNG HTC MY TOUCH
usually first time the code will be all zeros or last 4 of your phone #orr ss# depends on who set your phone up first time
May 25, 2012 | T-Mobile My Touch Cell Phone
How to perform a master reset
Hello,When you need the phone to be like the one when you brought the mobile phone. right? If so, First do the Factory Restore Default settings in Setting area, or use the Setup app in your HTC Mobile Phone, which is already installed in your HTC Mobile. But the apps you installed from Market gets erased and your phone will be like a new one(When you first brought the mobile phone and switched on the phone) with the HTC Company installed apps.
Oct 26, 2011 | HTC Wildfire Cell Phone
How to unluck my htc 8925 phone?
It is very easy to unlock your HTC cell phone.Simply enter unlock code through mobile keypad and get your HTC cell phone free to use any GSM network sim card worldwide.You can get unlock code by HTC UNLOCK CODE provider with Instructions.
THANKS ! ! !
Jul 01, 2011 | HTC TyTN II Smartphone
I have installed CHT editor software in my HTC HD2 around 1month ago.. It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem...
i have installed CHT editor software in my HTC HD2 around 1month ago..
It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem occurs..
bt after dat i switched off my phn n nw its demanding the security code which i entered d same with which i opened it many times...bt every time it is showing me wrong password... is there any solution 4 dat... i m pretty much sure dat i m entering d right password..
my mobile model is HTC HD2 T-mobile Leo, i bought it from USA n unlocked it in india...
Nov 24, 2010 | HTC HD2 Smartphone
How to hard reset the htc 710
to hard reset the htc s 710....................
1) switch off the phone first,
2) again switch it on....and as soon as the green led starts blinking (indication of phone coming to life) immedietly press and hold both the soft keys at a time, and follow the instruction given on u r phone screen. :)
Jul 09, 2008 | HTC S710 Smartphone
HTC G1 Smartphone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
