Question about Microsoft Xbox 360 Console
Intermittent E68 error code. is it console problem or hard drive?
  • 340 Answers
This could also be an eeprom error, this error occurs when there is not enough power getting to the console, so if you have any cooler fans or play and charge kits plugged in to the console remove them and see if this helps.
Remember thumbs up if this helps.
Posted on Feb 03, 2010
Testimonial: "thank you. console works ok but hd shows E68 when connected to console. will work ocassionally however"
    Sergeant:
    Champion:
  • 378 Answers
Harddrive.
Testimonial: "thank you. i suppose a new hard drve is the order of the day ?"
I was watching net flicks and my xbox rebooted and flashed a red ring (bottom right) and it said E68. i shut it off and started it up again and works<did that twice<the unit was alittle hot...
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
To fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft, as the e68 is generally believed to be related only to your console's hard drive/HDD.
Hope this helps.
Mar 06, 2011 | Microsoft Xbox 360 Console
Do i need a new hard drive if the one i have gives me the e68 error when it it in the xbox when it isn't in it turns on no red light but when i plug it back in i gives me it again. thank you.
Hello! no need to worry! the E68 error code is one of the more simple things to fix. most of the time it's just simply a hardware fluke. Attached you will find detailed instructions on how to successfully restore your hard drive and eliminate the e68 error code. If unfortunately, you must purchase a new hard drive, you can find reasonably priced drives at your local electronics or computer store.
If the steps listed in the link fail, the contact information for Microsoft is included as well. Good Luck!!
How to Fix The E68 Error Code
Dec 29, 2010 | Microsoft Xbox 360 Console
New halo xbox360 just opened system error E68
Hi here is the error code details>
E68: Hard Drive Error - Hard drive not DMA configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. Also this can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
let me know if you have any further problems or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 14, 2010 | Video Game Consoles & Games
One red ring, erra 68.
What you need to do is try using the console without the hard drive or with a different hard drive, one red ring means a hardware failure, and the error code e68 is in relation to the hard drive. If using the console with a different hard drive, or none at all doesnt work, ensure that the fans are working as they often also cause the e68 error and a single flashing red light.
I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
The xbox360elite the red light flashes and e68 comes up on the screen with different language on the tv screen is also showing.
E68 means that you have a bad hard drive. Take out your hard drive and turn the unit on to confirm. Once this is done just buy a new hard drive and your good to go! Or now Microsoft just released where you can use a Flash drive :]
Apr 05, 2010 | Microsoft Xbox 360 Elite Console
E68 red ring
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
Jan 29, 2010 | Microsoft Xbox 360 Console
E68 showing up on tv screen
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans. If the unit operates successfully without the hard drive, simply replace the HD. If the unit continues to show the error code with no hard drive connected, this will confirm that there are serious issue that concern the internal connection. Contact Microsoft in this case.the console will need to be repaired.
Nov 11, 2009 | Microsoft Xbox 360 Console
E68 will not play anything just said to enter e68
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the Cooling fans as well.
If the removal of the hard drive doesn't improve this situating, contact Microsoft for a repair ticket.
Jul 08, 2009 | Microsoft Xbox 360 Console
E68 error
Sorry to say you got a bad hard  drive. Call MS or take the system back to walmart for a new 1 because I dont think they will give you a new hard drive. Who knows they might, call and ask!
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
98 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
