Question about HP LaserJet CM1017 MFP All-In-One Color Printer
HP cm1017 Color M & Y don't print correctly
1)Magenta and Yellow doesn't print 'full blown' color. The color 'Red' came out 'Pink' rather. 2)They also mis-align - like creating a shadow. I can see a layer of red next to a layer of yellow, and they suppose to be overlap.
3)Color on both edges (left and right) seem to fade out.
Already did Cleaning, Calibrating, change of toners, air dust all interiors, update software & driver, etc..
Please help!
    Novelist:
  • 217 Answers
You've 2 0r 3 problems here.
First NEVER use an air blower in a laser printer. You'll just blow toner deeper into the printer and could make things worse AND there's potential for damage due to static from the air blast. I've seen priners that were working OK, but had a leaking cartridge in them - 'cleaned' using an airline, and they never worked again !!
Problem 1 - weak magenta and yellow.
This will have started with the magenta being weak, become weaker, and later the yellow will have also started to deteriorate.
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit.
Problem 2 - Misalignment (Out of register) colours.
Registration of the colour cartridges, so that they can be used together to produce the colours in between the yellow, magenta and cyan of the cartridges themselves, takes place during 'calibration'.
If one of the sensors on the Transfer belt fails, the calibration seems to take for ever (and actually fails), giving rise to this colour offsett. The sensor is not available, and not replaceable, you'd have to change the Transfer Belt.
Your symptom 3 is related to the problem 1 above.
Posted on May 09, 2010
You can run a test print to confirm outage, and then later the fix,
by pressing a small button inside a screw closed cover plate on the back of the Printer. Printout consists of a series of colored lines.
The following is pretty intensive. You may want to provide these
instructions to a techician so he will have some idea what to expect before he gives you a quote.
To access, remove and clean Laser Unit.
1. Remove both side panels; left panel has screw at bottom in
cavity. The right side has screw near bottom rear below
RJ45 jack. Do NOT pry apart at top, open the front of the
printer and pry the sides apart along front and bottom pull
out several inches and then slide downward to disengage top.
The front of the printer can be closed and the toner
cartridges even remain installed for the rest of this
procedure.
2. Remove back panel by removing 10 screws and swing panel
upward (hinged at top); disengage.
3. Disconnect connectors on both circuit boards (6 on left
board/15 of 16 on the right board) leave the 3 pin in
lower left corner of right circuit attached. Move all the
cables well out of the way; this requires the 3 black
plastic channels that hold the wires to be removed as well.
4. The two smaller channels have fingers that must be flexed
to allow extraction. The 3 ribbon cables exiting at upper
left corner need to be folded back and the metal "bridge"
flexed (almost bent) up to disengage tab and allow black
channel to be removed that's under it. Slide the long
channel left to disengage.
5. Remove 5 screws and then remove left circuit board.
6. Now remove the next panel by removing the dozen or so
screws around the perimeter. Two, in upper left and lower
left corners are screwed in from the side. Lift up bottom
a few inches and slide down to disengaging tabs at top.
The rather larger black rectangular Laser unit is now visible.
7. Remove the 4 screws and the Laser Unit. Disconnect the
2 ribbon cables and lift unit out.
8. Set unit on its back. Remove the small spring. Remove the
single screw from middle of cover, and then remove cover.
9. Short lesson: The 2 circuit boards on side have 2 each laser
which aim towards the middle of their respective chambers.
There is a square reflective device on a motor shaft called
a scanning mixer which when it spins directs the laser beam
to two respective prisms and then into the respective toner
cartridges. There is also a pair of Beam Alignment Lens
along each path.
10. OK, the top of the unit has the wire cable, if you examine
the prisms, the two lower ones in each respective chamber
will have a thin layer of toner coating them. Also the two
cupped looking clear plastic Beam Lens between mixer and
prisms could also have layer of toner. Anyway, clean the
Prisms, and both Beam Lens with Isopropyl rubbing Alcohol
and Q-tips swaps. Be careful, you do not want to dislodge
these components.
11. When I cleaned my CM1017 Laser unit, I was surprised at how little toner residue had the negative effect. Apparently it
doesn't take much residue to render the laser ineffective.
This explains the advice not to attempt blowing things out
with a can of compressed air. Although with the laser unit
dissembled and removed from the printer, you may want to blow
it out after cleaning to remove any microscopic debris left
behind.
12. OK, when all is spotlessly cleaned, you can install the cover,
if you had removed the plastic shutter rod to enable cleaning;
make sure it is put back in unit. Screw on the lid. Reattach
spring. Test operation of shutter.
13. Reinstall the Laser Unit, attaching two ribbon cables and
making sure shutter arm engages correctly.
14. Reassemble in reverse order, steps 6 thru 1.
15. Run test print via the button on back of printer (under
screwed cover plate)
Oh, when I first turn on the printer, the display panel would not come on. I turned off and back on the and the display came on.
I hope this makes your day!
LeEric Marvin
Posted on Aug 22, 2011
    New Friend:
Http://youtu.be/9r6PRbTP0bs
Check this video and follow the steps.
Be careful but you will get perfect result.
Posted on Dec 30, 2012
I have the same problem, anyone know the answer
Val
Posted on Jan 24, 2011
  • LeEricMarvin Aug 21, 2011
    You can run a test print to confirm outage and then later the fix by pressing a small button inside a screw closed cover plate on the back of the Printer.
    To access Laser Unit.
    1. Remove both side panels; left panel has screw at bottom in cavity. The right side has screw near bottom rear below RJ45 jack. Do NOT pry apart at top, open front of unit and pry sides apart along front and bottom pull out several inches and then slide downward to disengage top. The front of the printer can be closed and the tone cartridges even remain installed for the rest of this procedure
    2. Remove back panel by removing 10 screws and swing panel upward (hinged at top)., disengage.
    3. Disconnect connectors on both circuit boards (6 on left board/15 of 16 on the right board) leave the 3 pin in lower left corner of right circuit attached. Move all the cables well out of the way; this requires the 3 black plastic channels that hold the wires to be removed as well.
    4. The two smaller channels have fingers that must be flexed to allow extraction. The 3 ribbon cables exiting at upper left corner need to be folded back and the metal “bridge” flexed (almost bent) up to allow black channel to be removed that’s under it. Slide the long channel left to disengage.
    6. Now remove the next panel by removing the dozen or so screws around the perimeter. Two, in upper left and lower left corners are screwed in from the side. Lift up bottom a few inches and slide down to disengaging tabs at top. The rather larger black rectangular Laser unit is now visible.
    7. Remove the 4 screws and the Laser Unit. Disconnect the 2 ribbon cables and lift unit out.
    8. Set laser unit on its back. Remove the small spring. Remove the single screw from middle of cover, and then remove cover.
    9. Short lesson. The 2 circuit boards on side have 2 each laser which aim towards the middle of their respective chambers. There is a square reflective device on a motor shaft called a scanning mixer which when it spins directs the laser beam to two respective prisms and then into the respective toner cartridges. There is also a pair of Beam Alignment Lens along each path.
    10. OK, if you examine the prisms, the two lower ones in each respective chamber will have a thin layer of toner coating them. Also the 2 cupped looking clear plastic Beam Lens between mixer and prisms could also have layer of toner. Anyway, clean the Prisms, and both Beam Lens with Isopropyl rubbing Alcohol and Q-tips swaps.
    11. When I cleaned my CM1017 Laser unit, I was surprised at how little toner residue had the negative effect. Apparently it doesn’t take much residue to render the laser ineffective. This explains the advice not to attempt blowing things out with a can of compressed air.
    12. OK, when all is spotlessly cleaned, you can install the cover, if you had removed the plastic shutter rod to enable cleaning; make sure it is put back in unit. Screw on the lid. Reattach spring. Test operation of shutter.
    13. Reinstall the Laser Unit, attaching two ribbon cables and making sure shutter arm engages correctly.
  • cyntheniaj
    cyntheniaj Sep 10, 2012
    Help! Did everything listed and now I have no power at all. Any suggestions?
Red is printing pink.
A manual and troubleshooting guide for your printer can be found here.
May 05, 2008 | HP Color LaserJet 2600n Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Pink copies
Most printers is run by 4 colors black and the colored is basically yellow red blue. (or may called it magenta cyan etc)
1. One of you colored ink runs out that why you cant make any colored.
2. Or one of the basic color might be clog up, dry or simply empty.
3. you need all the 3 colors to make all the colors available.
e-mail me at wendel_tenebroso@yahoo.com
good luck
Apr 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet CM1017 MFP All-In-One Color Printer Logo
2,454 people viewed this question
Seeker5211
Seeker5211
