Question about Transcend (TS40GSJ25) 40 GB Hard Drive
Cant partition my external HD
My external hd cant be recongnized..
it shows up in MY COMPUTER..
but when i open it and try to make a new folder it says:
THE SYSTEM CANNOT FIND THE SPECIFIED FILE...
it cant be partitioned or reinstalled...
wwwwwahhhhhhhhhhhhhh!
  • Fiqc Jun 09, 2008
    the program answer mi that I need give a format to the external disk but this is impossible maybe. Sorry my english is not so good, but if you understand Spanish.
    Por error formateé el disco externo y ahora al querer darle formato no sucede nada.
    Gracias, espero me puedan ayudar
  • 62 Answers
Try using diskmgmt.msc (from run) diskmanagement utilty or the partition magic software to format that would certainly help you
Posted on Jan 19, 2009
Coolmax HD-360B-U2 USB 2.0 External hard drive shows up on computer but I can't see anything that is saved on it. computer shows that there is data being used on device but when I open it, it says the...
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Feb 16, 2014 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Needed is an operation manual "how to" for HGST Touro 4TB external hard drive machine just bought. Want to know how to transfer files from computer to external storage?
FIRST the short ANSWER; Open Windows Explorer and drag and drop files/folders to new drive.
LONG ANSWER; Connect drive,during boot up of PC, and ENTER (CMOS) SETUP. See if drive is listed.
IF LISTED resume boot and see if Windows FINDS new Hardware and installs it. If so go to short answer.
If not seen by windows but seen by CMOS the drive must be PARTITIONED and then FORMATTED. OR
IF disk came with install CD run install to assure all needed USB drivers are present for windows to install disk through USB port.
Once USB drivers are installed reboot PC and see if Windows finds new hardware.
IF windows still does not install new HD but CMOS shows drive is present, the drive needs to be partitioned.
To partition new drive type DISKPART at dos prompt or in START RUN OPEN and press enter.
At the DISKPART> ( prompt ) type LIST DISK then press enter.
Example: DISKPART> LIST DISK press enter
FIND the number assigned to the new drive in the list (#), then type SELECT DISK #
Example: DISKPART> SELECT DISK 2 press enter
the info returned in the dos window should be;
Example: Disk 2 is now the selected disk
Type CREATE PARTITION EXTENDED
Example: DISKPART> CREATE PARTITION EXTENDED press enter
Now shutdown the PC then reboot. Windows should now Find hardware and install new disk.
Click START then COMPUTER the new disk should be listed.
Right click on the Drive and select FORMAT use NTFS format.
now you should be able to drag and drop files/folders to your new disk.
Oct 16, 2013 | Computers & Internet
My iqon hard drive will power up but i cant access it
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Source
Nov 26, 2012 | Computers & Internet
My coputer isn't recongnizing my camera? Please help as I have pictures i would like to upload
Normally you would connect the camera to the computer via the mini USB cable then turn the camera on. The computer will see a new storage device and consider it as an external HD an icon should appear somewhere on your desktop. Before you do all this create a folder in "My Documents" when you open the camera/hard drive copy the folder and paste it in the new folder you just created.
The eject the camera hard drive icon and remove the camera the image files are now on your computer hard drive.
Dec 12, 2010 | Casio Cameras
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
Hi from Portugal. I have got a mobo a8n-sli SE and im having trouble connecting my new wd 64mb 1gb green sata HD. I already have got 2 working hd´s, one IDE 128gb and one Sata 320gb and now i...
ur mother bios should support 1TB HDD, only then it ll get detected... u can update the bios of your motherboard with latest bios that is available for ur board in ASus support site...if you update the bios your hdd may get detected...
Sep 30, 2010 | ASUS A8N-SLI Motherboard
HI, TRANSCEND EXTERNAL HARD DISK FOLDERS NOT OPENING
try to format the HD using disk management. right click computer select manage then disk manager. look for your external HD and click format.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 26, 2010 | Computers & Internet
I cannot create new folders on my external HD
If the explorer shows you have some space left and can not create any file or folder, it might be because of heavily fragmented drive. try defragmenting thr drive using any application. I usually use O&O defrag .
Sep 16, 2009 | Western Digital My Book Essential Edition...
Trying to read external HD, unknown partition
I see that you have a loss partition of your External HD. It is totally damage partition.
Here's what you do Replug your External HD to another PC if it is OK. Maybe its not the same will appear on your PC too.
Unknown Partition are likely big trouble to us if we have needed files inside.
Partition on every HD, External or USB are very needed, if you lose it. Then again reformat that to use again.
Hope its not gone. Good luck!
Aug 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
USD HD folder Showing empty even though the HD shows as 96% full.
Sir,
This is the problem of worm, virus. Now-a-days virus is disturbing entire system. U must update your anti-virus, Purchase a full version including total internet protection, update the OS(operating System), Full Scan the system. it must be cleared
Thanks
Good Luck
Jul 24, 2009 | Western Digital My Book Essential 1TB...
Transcend (TS40GSJ25) 40 GB Hard Drive Logo
94 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
