Question about Pentax Cameras
Batteries extracted while the camera was "on". Now nothing works.
The batteries were extracted while the camera was "ON". when NEW batteries were inserted the lens remained in the extended position and the camera functions are dead.
  • Geoffrey Bull Feb 03, 2010
    Thanks for your reply
    I have tried reinserting the batteries after much more than an hour. Nothing happens!
    Model no is Optio 30 There are other numbers if you want them.
    The batteries show a charge of 1.35 v and 1.38 v respectively.
    Hope this helps
    Geoff
Hello
After the new batteries are insterted, does the on/off swich give any sign or trying to pull the zoom lens back in, or any sign of turning on and off? If not, does the camera have a power cord with it that you can attempt an on/off with?
Thanks
Posted on Feb 03, 2010
  • 3,230 Answers
Well first of all you can try to reset your camera, just remove the battery from the camera and left it for 1 hour after then again check by inserting the battery. please let us know the model number of your camera for more help...... may be the firmware of your camera is corrupted or some hardware problem..... please reply for more help or information.......
Good Luck!!
Thanks
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new ones.now nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
Mar 20, 2011 | Kodak EasyShare C533 Digital Camera
Camera won't turn on to take pictures~
This is a common problem related to batteries. Use 2100mA or higer batteries fully charge batteries. This problem occurs when you use alkaline batteries or faulty NiMH batteries. To solve the problem try with new fully charged NiMH batteries.
May 14, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Power button does not seem to work have put in new batteries but nothing happens
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Dec 07, 2009 | Kodak EasyShare C613 Digital Camera
Put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
Aug 20, 2009 | Kodak EasyShare C663 Digital Camera
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
Camera shows "exhausted batteries" with new ones.
i have this camera and i had the same problem
everytime i put in new batteries like 5 seconds later the battery was exhusted i tried cheap and expensive batteries but nothing seemed to work
i would recomend rechargealbe batteries because they last longer but if you prefer one-time use batteries you should change they battery type in the menu/ setup
hope this helps!! good luck
Jun 03, 2009 | Nikon COOLPIX L18 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Battery/Docking Station
I have a working used one if you're interested. Google my username, and I can help out... ;)
Jan 11, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Dead?
Have exactly the same prob, my camera worked for 3 years without any probs, except that the alkaline batteries didn't have a long life...tried rechargeable batteries as well, but since three weeks ago it simply says, "batteries depleted", nothing works, tried everything...sending it to Pentax after the warranty is over is far more expensive than buying a new cam...really sorry for that, but don't think I gonna buy a new Pentax again...
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Cameras Logo
21 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
