Question about Britannia SIE9TLS Electric Kitchen Range
I have a 12 year old Britannia si-9t and the over door Fails to close properly I have checked to spring hinges and they seem ok any suggestions Regards Den
3 Suggested Answers
  • 1550 Answers
SOURCE: where can I obtain a user manual for Britannia
CHECK OUT THE LINK BELOW IT WIL BE USEFULL FOR YOUhttp://www.google.co.in/search?q=Britannia+model+number+SI-9TF-GRA+Close+Close+&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Posted on Jun 10, 2009
SOURCE: Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Posted on Aug 07, 2010
Can I change the grill element in my britannia oven from the front Type is SI 9T
I thought theses were removed from the top after removing screws or clips that attach the unit to surrounding surfaces.
Could be wrong. But they are usually simple enough for the home owner to remove.
Oct 19, 2013 | Britannia SIE9TLS Electric Kitchen Range
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Feb 11, 2010 | Bosch Ovens
I have a Frigidaire FDB2410LDC3 Dishwasher. It was working great until my 5 year old fell on the door and it does not spring back up now. I tried looking with a flashlight in the sides and the springs...
Prhandle and latch.obably sprung the hinges. The reason it dont want to work right is the door latch is not latching properly and therefore it wont start. I would start by replacing the hinges and springs and the
Dec 30, 2009 | Dishwashers
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Dec 30, 2009 | Ovens
Where can I obtain a user manual for Britannia model number SI-9TF-GRA
Jun 10, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
MAYTAG MDBO880AWB LEAKS FROM LEFT SIDE DOOR ONLY SOMETIMES AND
If the door is sprung in a manner that one side is flush and not other then most likely the hinge has been bent outward by the weight placed on it.the best solution would be to replace hinge,the spring only adjusts the tension for door closing. There is a slight possibility that either the frame or the door has bent in this manner so before buying hinge check frame and door for damage,after doing repair would suggest adjusting front legs of unit to raise front up a bit to ensure leaking wont continue
Apr 21, 2009 | Dishwashers
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Sep 01, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Britannia SIE9TLS Electric Kitchen Range Logo
166 people viewed this question
Top Britannia Kitchen Ranges Experts
James Gettemy
Bill Boyd
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
