Question about Exercise & Fitness
How do i releave preasure on the rear calipar to re-fit rear wheel
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Disc?v-brake? discs should be able to be changed with out any adjustment. the vbake should disconnect at the wheel side depending on type.
Posted on Feb 04, 2010
Hot water coming out of hot water heater. !!!
THATS` THINGY IS THE PREASURE RELEASE VALVE. THERE A ONE SHOT WOUNDER THAT MEANS ONCE THERE OPENED THEY NEVER CLOSE COMPLETELY.IT HAS TO BE REPLACED.IF THE TANK IS RENTED THEY DO IT FOR FREE .BUT IF YOU OWN IT YOU HAVE TOO DO IT .IMPORTANT!!!!!! THE RELEAVE VALVE IS VERY IMPORTANT, IF NOT REPLACED WITH THE RIGHT ONE THE TANK CAN BLOW UP.
Feb 07, 2013 | Water Heaters
Where is the fill plug for 1999 mecedes slk 230 hydraulic roof pump
Should be a screw on top of the pump - upper right side.
It should fit a hex/allen/key size 5.
Oil level should be between min and max.
After filling, tighten screw with 8NM torque
If you look down through the "brush", you'll see the screw.
The screw on top of the pump is for the refill, the one on the side is to releave the preasure when you open the top manualy. There is a refill line on the side as well.
Sep 14, 2012 | 1999 Mercedes-Benz SLK
How to compress rear brake piston?
take a c clamp and compress it in or it may be the type that has to screw back in and they make a special tool for them,which you can take a pair of channel locks and twist them in also.
Feb 02, 2011 | 1983 Nissan 280ZX
Rear wheel cylinder went out replaced that on both wheels an brake lines.then replaced master cylinder.Bleed the brakes but got no preasure at the pedal.Cant find any leaks .
you have air in the lines or a leak somewhere. tighten all your fittings and start at the pass side rear wheel. get a piece of vacuum hose that will fit on the bleeder and put one end on the bleeder and one end in a cup half full of brake fluid. have someone start the truck and pump the brakes slowly and watch the cup for bubbles. when the bubbles stop go to the next wheel if they dont stop after five minits of pumping you have a leak. i worked for hours on a truck finally finding a very small leak in the hose that goes from the rearend to the line down the frame. some part stores rent or loan vacuum pumps for doing brakes that work great just hook up to the bleeder and turn it on making sure that the master cylinder stays full and it pulls the fluid thru removing all the air.
Dec 18, 2010 | 1991 GMC Sierra
On a 1994 Chevy s10 pick up, how do you change the front brakes?
jack up frt end. remove wheels. take note of how the brakes go together. do 1 side at a time so you can use the other side as a referance. remove caliper bolts. use a c-clamp to push in caliper pistons. remove old pads. than remove caliper bracket and rotors.dont be afraid its not a big deal. make sure to check brake fluid level and pump the pedal when the job is completed.
Nov 19, 2010 | 1994 Chevrolet S-10
What are the torque specs for the bolts on the brake rotors/calipers?
FRONT CALIPAR TO CARRIER 34NM
FRONT CARRIER TO HUB 107NM
FRONT HUB NUT 294NM
REAR CARIER TO HUB 62NM
REAR CALIPAR TO CARRIER UPPER BOLT 39NM
LOWER BOLT 34NM
Apr 25, 2010 | 2003 Toyota Camry
I have a 1992 Chevy 1500 4x4 the right rear wheel has locked up. I took the brake drum off and it looked like the brake shoes are not releaseing. What would cause that?
frozen or engaged parking brake cable or possible bad brake hose but that would cause both to lock is the other wheel cylinder leaking? that would releave pressure from the wheel . a fluid leak (axle seal or cylinder) can cause the locking feeling because it slips then catches when the fluid wears off hope this helps
Apr 06, 2010 | 1992 Chevrolet K1500
How easy is it to replace rear wheel bearings and seals in a 2006 odyssey?
first remove the wheel then remove the brake calipar held on by 2 14mm bolts, then remove the rotor, and then there are 4 bolts that hold the bearing on from the back side remove those and the bearing will come off
Dec 22, 2009 | 2006 Honda Odyssey
How do you remove the rear rotors from a 2007 Dodge Minivan?
Disc only!!! Remove rear tire. Remove 2 calipar bolts. Hang calipar. Don't leave hang loose. Slide rotor off. If stuck you must adjust the emer. brake, Going around the back side of the backing plate on the bottom. Remove the rubber boot. Using a brake tool or screwdriver adjust the star wheel adjuster to remove the rotor.
Oct 08, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Exercise & Fitness Logo
18 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
