Question about Smeg 27 in. SPV577X.1 Gas Cooktop
SPV577x Hob The large burner on my SPV577X hob will not stay lit. Can suggest a solution? Is this something I could repair myself?
  • Anonymous Jun 03, 2008
    same problem..... takes ages to come on, stays on for a few minutes and then goes off..... the process then repeats.
  • verdigris623 Aug 31, 2008
    I have a 6-ring Smeg gas oven with hob and 2 of my hob burners now will not stay lit. I suspect this is the mercury filament prpblem but I do not know how it can be fixed.
    Any ideas what can be done to get my burners to stay lit??
    Thanks
I think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Posted on Aug 10, 2008
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
We have a problem with two of the burners on our Bosch hob which refuse to stay lit, at certain times. The problem is confined the front burners (medium size), with the largest and smallest burners which...
Remove the brass burner heads.Remove the Butterfly nut ( in some models just a screw ) and remover the cast iron base.At the narrow end there is a nozzle with a small pin hole which couples with this pipe. Take a fine needle or pin and insert into the small hole and clean. Reassemble and Voila !!!! bobhifi.jpg
Mar 07, 2011 | Bosch NHT645SGB Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Electrolux insight cooker EKT6045 problem with hob controls
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
Aug 11, 2009 | Electrolux Cooktops
Four burner gas hob
You have to turn the knob a little farther, past the light stage. Sometimes they're not marked quite like they should be.
Jan 04, 2009 | Cooktops
Hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
Dec 05, 2008 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
we have the same problem... try removing the knob, ours works fine without the knobs ????
Dec 19, 2007 | Baumatic 24 in. B40 Gas Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Smeg 27 in. SPV577X.1 Gas Cooktop Logo
731 people viewed this question
Top Smeg Cooktops Experts
ray gallant
marlin siecinski
Bill Boyd
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
