Question about Crosley Refrigerators
Ice build up on coil in freezer - Crosley Refrigerators
  • 619 Answers
Using a hair dryer defrost all of the coils. There are 3 things that will cause this. First the defrost timer, 2nd the defrost t-stat and last the defrost heater. Most of the time it is the defrost t-stat that is the cause of thisproblem. It is located on the coils and has 2 wires comimg off of it with one wire going to the heater and the other going to the timer. Hope this helps. Very easy and inexpensive to do if you take your time. Hope this helps.
Posted on Feb 03, 2010
Refrigerator will not stay cold and ice is building up in freezer.
your compressor or condensor or capacitor is bad, need a technician
Dec 11, 2015 | Maytag Refrigerators
WHY IS THERE WATER IN BOTTON OF FREEZER AND ICE MAKER NOT MAKING ANY ICE
You have an iced up evaporator (cooling coil). This coil is usually located in the freezer section. A small fan distributes air across this coil and into the refrigerator. If coil is block with ice, no air can be blown across the coil. Coil is blocked with ice due to failed defrost timer on main circuit board or a failed defrost heater.
Jul 14, 2014 | LG Refrigerators
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Ice building up on freezer coils
sounds like the fan for the freezer is not working
Apr 03, 2009 | GE GSS25LGM Side by Side Refrigerator
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
122 people viewed this question
Top Crosley Refrigerators Experts
Colin Stickland
Colin Stickland
fta777
ray gallant
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
