Question about Toshiba MK6034GAX (HDD2D17) 60 GB Hard Drive
My external hardisk is showing in device manager but it is not showing in disk manager
  • 10 Answers
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your bios settings
Posted on Feb 03, 2010
My external wd elements not reading and the light in the hardisk is on but not blinking
Could have picked up a virus from your friends computer, or the device is just on the fritz. It also could have been corrupted. When removing an external hard drive you should always go to the bottom right click on the little green arrow icon and select "safely remove <your device>" otherwise you risk corrupting the files on it. Plug in the hard drive to your computer. Right click on Computer/My Computer and select Manage. Click on Disk Management on the left side. If your device shows up then the drive most likely has corrupted files or the file table. Right click on your device and initialize it if it isn't and then format the device and it will work again. You will lose all your data in the process. You can download Recurva from piriform.com to try and recover your files if you like. If the device doesn't show at all in disk management then I'd say its toast.
Dec 01, 2012 | Western Digital Computers & Internet
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
Boot device not found Please instal l an operating sistem on your hard disk. Hard Disk - (3FO) F2 Sistem Diagnostics Foe more information, please visit: www.hp.com/go/techcenter/startup
please go to the bios setup by pressing F2. then check your sata hardisk if detected. if not, remove the sata hardisk and use it as external by using external sata case adapter. then plug to the other pc and check if spinning or detected by another pc. once not detected or spinning change your sata hardisk. but if detected, there is a problem on your dv6000Z notebook.
Feb 01, 2011 | HP Pavilion dv6000z Notebook
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
Hard Disk drive do not appear in Disk Management & Device Manager
to fix the problem you must open your laptop check the hardware inside of your laptop hardisk thats the problem try to unplug cables of hardisk to plug again or replace new hardware hardisk if not solve the problem
Jun 18, 2010 | Lenovo 3000 Y410 Notebook
I have an Iomega MiniMax Hard Drive that was previously formatted for a Mac. It is supposed to be 500gb but when I format it for my PC it only shows about 234gb in the primary partition. How can I regain...
connect your harddisk to computer.
Then right click on my computer icon then click on "Manage"
then click on "Disk Management"
then find your removable device then you find unpartitioned space create new partition .then check.
Also check jumper settings of your harddisk.
It should not be on 16 bit or 32 bit in hardisk.
Jul 16, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
External drive not showing up
Have you gone into disk management?
If it is vista, right click on my computer, and manage, disk management.
Check and see if the disk shows up there. If so, you will probably need to format it.
Vista has it's own format, and does not like the usual XP disk. I just went through this.
Apr 07, 2009 | Acer Aspire 5610-4648 Notebook
USN external harddisk
You shouldnt need drivers unless its a Windows 98 PC. Right click my computer and select manage, when the box pops up select disk management. You should be able to see the drive and format it for use.
Dec 30, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
New hard drive is 320gb but its only showing 54.4 gb ?
i think u have to partitioned your hdd.
go to computer management right clikm my computer icon then u see manage then clik on it.
then go to disk management.then u se your hardisk then partiotion the river then u can see all capacity.
Dec 29, 2008 | Dell Inspiron E1505 Notebook
Toshiba MK6034GAX (HDD2D17) 60 GB Hard Drive Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
