Question about Vizio L32 32 in. LCD HDTV
Vizio Speaker Making a Buzzing Noise
We have Vizio television and when turned on, the internal speakers in the television have a buzzing noise that doesn't stop until the television is turned off. Is there anything we can do to fix this problem?
  • 2 more comments
  • bwalker98 Mar 10, 2008
    My 46" Vizio has the same problem, any suggestions?
  • Anonymous Jul 16, 2008
    I have the same problem. The first TV started making the sound about fours hours after I bought the TV. I took it back and brought a new TV home. This TV was fine for about two weeks and now it is making the same cracklin sound.
  • Anonymous Dec 25, 2008
    I am having the same problem and seems that the speakers are vibrating in the housing. I have had mine for almost a year now, so out of warranty. Anyone else have any bright ideas as to how to fix this annoying problem???
  • Guest Jun 27, 2013
    I have had the same problem with mine for a long time and had hooked my TV up to external sound output anyways. The long term problem has been that I have to turn off the internal speaker via the TV menu every time I turn the TV on. Is there a permanent way to turn off the internal speakers?
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Posted on Apr 25, 2009
Speakers in TV making a buzzing noise.
Try a reset to default settings. If that does not clear it I would suggest that it is either a hardware fault or interference
A constant buzzing might be interference from the power control card. What happens if you move the set elsewhere. Also, try it on another aerial, maybe there is a problem there....perhaps
Apr 25, 2015 | Polaroid FLM-3734B 37 in. LCD HDTV
Vizio E320VL has a buzzing or static sound coming from the right speaker.
You may have blown your right speaker if you max the sound allot, you may need to replace. Hope this helps- Pleas comment
Mar 17, 2011 | Vizio E320VL 32 in. HD Ready LCD TV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Audio buzzing
check where your pluging the red sounds like your pluging a video signal into an audio jack or your red cable ha an open ground
Dec 22, 2009 | Vizio L37 Television
My vizio 37 is buzzing from the back. not from
try to unplug some cables from the T.V like PS3/PS2/Xbox ect, or check your VCRs or DVD players cables by taking them off to see if the noise goes away. My crappy t.v makes a buzzing noise when i connect external speaker or VCRs or my PS3
Aug 25, 2009 | Vizio L37 Television
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
Mar 08, 2008 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
3,110 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
