Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
My apple 13-inch MACBOOK got water damage, after drying it out for a couple days with the battery out, computer worked perfectly fine... EXCEPT it would SOMETIMES act as if the shift key is held down. (its evident when i click the keyboard viewer) i) when restarting the computer, will safe boot itself ii) suddenly when typing letters will be capitalized, numbers will turn into symbols iii) shortcuts (copy paste etc) will not work, and once in a while my sound key (F10-12) responds, but will not allow for sound to come out of the speaker ... WHAT is wrong with my computer? and how can i fix it? should i get a new keyboard and attach it to my comp? thanks in advance
@ devilzback_1:
I just spilled water on my Macbook Pro and am having the exact same problem you experienced. Did you ever find a solution? FYI I ready thru the 2 solutions here but am not tech savvy.
Thanks in advance for any help.
Posted on Feb 26, 2012
  • 846 Answers
First off remove the battery and , put it in a warm and dry place for a few days. If that doesn't help open the Laptop and clean and dry it out as much as you can. Here's a guide on how to disassemble an Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have a service do it for you there are third party Laptop Repair Services.
Posted on Sep 14, 2010
  • 109 Answers
Your issue seem to indicate there was damage to the keyboard when it got wet. Drying out the laptop may have gotten it to function for now but it isn't really a substitute for a thorough cleaning by a professional (which might also solve your keyboard issue).
Posted on Feb 03, 2010
Screen wont light
These had issues with the inverter that is on the mother board and a pig to fix!
Mar 06, 2014 | Apple Macbook Air 2nd & 3rd Gen 13" -...
Baclight not working some water inside keyboad
sorry no fuses on mac, if water gets into any electronics put the entire unit into dry uncooked rice. check the apple website for resetting the EMC, this might help
Feb 03, 2014 | Apple Macbook Air 13 Intel I5 4gb Ram...
Water spilled on the table under the macbook. now it doesn't work. I see people wating a few days and it restarted. how nmany days should i wait? help!!!
Jay, Try placing your MacBook on a bed of un-cooked rice for several days that should pull any moisture out of your lap-top. DO NOT ATTEMPT TO TURN IT ON. If you already have it may too late.
May 06, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook a1181 works for a couple days and then does not want to start again for another couple days. please advise
Your best bet is to reset the System Management Controller;
(I'm not sure if your model has a removable battery or not, so I'm providing both methods)
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
...and then reset the Parameter RAM:
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Nov 17, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Macbook got wet and now the speaker wont work !!!!
The audio port section and battery internal connector are both is same place.so may be there is a sort of connectivity happening.dry the laptop for few days and then use.hope the issue will resolved.
Mar 16, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Hello there!! I have a macbook grey, 13" the new one's, unibody enclosere!! ok.. here's the thing my keyboard got wet, I took out the battery, put it apart all night long, but now keys won't work.. track...
You're on the right track... turn it upside down with the battery out and leave it to dry for at least 5 days. You can also try buying a large container of silica crystals at a hobby shop and put the computer and the open container of silica in an oversized plastic bag... If the water wasn't water, there will most likely be residue... but all this is worth a try... other than that, it can be disassembled and dried out and any damaged parts replaced... good luck on this.
Jun 17, 2009 | Apple MacBook Housing, Top Case with...
Wet laptop
Water = No more warranty. You or a friend can open up this laptop (be careful and take note of all screws and parts) Remove logicboard (aka motherboard) and take a tooth brush and rubbing alcohol mixed with water and scrub that logicboard down - remove any corrosion, then let dry for a day (water between chips & board dry slowly). We've fixed submerged Apple laptops this way, and one all corrosion removed, laptop will have a 90% chance of working again. You really can't kill an Apple with water - you only really put it into a coma. The faster you can get electricity (battery or power adapter) removed after water incident, the less corrosion you will likely have to clean up after drying. Apple laptops generally have short safety's on the logicboard to keep the board from burning up if it senses a short and they won't power up until the short is removed.
You can fix it!
Mar 28, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Water fell on my mac
By all means do not turn it on.....u might fry something. Leave it in a dry hot area for like 2 says. Then you might have to take it to Apple because Mac's are very very picky about water, i spilled coke and it fried it!
Feb 10, 2009 | Apple MacBook Pro Laptop Computer with...
Microphone on Apple Macbbok 13" 2.4 GHZ,2GB
Check to see if the microphone works on the macintosh side of the computer, chances are it won't, microphone usage on Macintosh computers has been hit and miss, sometimes the microphone needs a pre-amp or USB interface like a Griffin iMic adapter.
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Water on MacBook Pro!
Well, Spilling water on your computer sure isn't the smartest thing to do, but it's not sure the damage is too big. Let it dry for a few days: take the battery apart and leave it in a well-ventilated room for a couple of days. When it's nice and dry, try turning it on. If it works - great! If it doesn't, you might want to get it repaired at a professional soon. Actually, taking it to a pro might be a good idea anyway. Good luck!
Aug 01, 2007 | Apple MacBook Pro Laptop Computer with...
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
899 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
