Question about Whirlpool Washing Machines
Program keeps going round and round without washing or rinsing
  • 51 Answers
The machine you have does give problems with the module and they can be expensive to replace. It might not be the module however. your machine does a self test diagnostic upon startup, it checks every component and if it detects a faulty part, the result is that it just clicks around back to the stop position. this is not a repair that you would be able to carry out yourself unfortunatly. most commonly however, the brushes may need to be replaced, this you could do yourself though. UNPLUG the machine from the wall, put the machine on its side(soapbox side on the floor IMPORTANT) and remove the carbons(brushes) from the motor, if they are worn, they will be very short in length and the surface of either one or both will have a burned black mark, they should be shiny, this is the part that makes contact with the motor.
replacing these, if they are worn, will solve your problem, but if they are not the case, you will need to call out an engineer im afraid.
Posted on Feb 03, 2010
My washing machine stops right-after washing without rinsing, spinning
Did you try having the control board tested for faults?
May 07, 2012 | Washing Machines
Hi, our washing machine starts to pump out water and then stops. The counter still keeps going but without the machine actually doing anything. The water doesnt drain out sometimes and the no drain light...
Possible failure of the main program controller unit as it fails to contact at times and resets .
Since you mentioned that it is erratic the program is not executed to contact to the job of the cycle and so the drain pump/valve is stopped mid way.
Mar 25, 2011 | Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
My washing machine keeps stopping on the rinse cycle and then i have to skip the cycle for it to keep working.
at any stage have you interchanged the hot and cold hoses due to a valve failure unless programmed the washer will call for cold water on rinse cycle but usually will fault if no fault occurs possible control board problem let me know how you go
Nov 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
If the washing machine is on the rinse cycle should it not agitate the clothes?
Some washers have a static rinse as well as agitated rinses, but normally they rinse with the drum or agitator going round, if yours does not agitate on any rinse, then there is a fault. which needs investigating.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Washing Machines
I have just disconnected the inlet pipes on my Zanussi FJ1296 Washing machine but forgot to look which way round the go for putting them back - I can see no indication on the machine as to which inlet is...
inner one is hot and outer one is cold.
to check after fitting hoses, put on rinse program and only cold water should come in. if hot water comes in then you have the hoses wrong way round.
Aug 27, 2008 | Zanussi Washing Machines
My Indesit won't advance, won't complete a cycle
Suggestion: Try cleaning your outlet filter. This needs periodic cleaning, according to your usage. Refer to user's manual re. the cleaning. When it is the rinse problem it usually is the filter block. W
Oct 05, 2007 | Washing Machines
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
