Question about Saeco Odea Go
Saeco Odea Go - Hot water leaks from bottom of machine
It grinds the coffee and then hot water (not coffee) leaks from the bottom of the machine and that's that! In other words, the ground coffee and water don't get mixed, and no coffee comes out of the dispensing head (even though the steam spout seems to work to some extent -- some water still leaks from bottom when testing the steam spout alone).
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
Did t=you check if the valve that goes to the brew group is broken and lose??
also when you try to make a coffee the water comes out from the steam want? if so. is a leak in the steam valve that all the pression comes aout from there and no pressure goes to the brew group.
Posted on Jun 18, 2010
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
I have a Saeco Giro that leaks coffee under the machine
check the brew unit .there is something wrong with "O" rings
Oct 07, 2014 | Saeco Odea-Giro Espresso Machine
Hot water steamer does not work properly
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Dec 15, 2013 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go descaling
fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Dec 02, 2013 | Saeco Odea Go
Water is leaking in the back of the machine. What needs to be done?
It's from hot water/steamer distributor. Must repair at once, cause can fault other things (printed circuit board)
Nov 03, 2013 | Saeco Odea Giro Plus Coffee Maker
Saeco grinder
Maybe the piece that direct cofee to brew group it is missing, so all cofee fall down.
Oct 04, 2013 | Coffee Makers & Espresso Machines
Hi i have a Saeco Odea Giro Plus, that was broken ceramic baked klay. after replace new it have a problem with my Saeco Odea Giro. The problem is that the bean grinder doesnt grind (I only hear sound of...
you need to change this part ,which is under the ceramic knife. You will have to open the coffee grinder and take out the knives and change the holder to the lower knife. That's your problem. This is the product code 149198350
Apr 22, 2017 | Saeco Odea-Giro Espresso Machine
MY Saeco italia has been leaking everytime it pulls a shot from the bottom of the unit. I opened the machine and the steam valve area is dry as with everywhere else. The only part that's wet is the...
it is also possible that the leak came from the pump as well most likely your lines are also clogged up with fine ground coffee past the brewer which stops the water from flowing and causes excess pressure which eventually either busts a water line or makes the pump push the water out past the caseing of the machine. Very time consuming finding the leak as well as replaceing the parts that are broken. If you have any further questions message me back. Thanks
Rick
p.s just curious because i ask all customers dealing with coffee and expressor machines what was the grind set to when you ground your coffee?
Sep 28, 2011 | Starbucks Saeco Italia Digital Barista...
When my Keurig one cup dispenses the hot water onto the filter the water goes everywhere (making a mess) but not through the coffee filter & grounds.
Possible clogged water output house. Question? Is the water going on the filter then overflowing? If so, the grind of the coffee might be to fine. Might have to have the grounds a little courser. To test put no coffee in and if flows through ok, then coffee is ground to fine, then just need to have it ground a little courser. Thanks, mike
Jun 08, 2011 | Keurig B60 Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
2,440 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
