Question about Acer Aspire 5920-6335 Laptop
Not charging hi my acer laptop has stopped charging all of a sudden. the battery became low and eventually died. I thought the charger was faulty and bought a new one but with that also it won't charge. I decided to test it using an old acer laptop i had that too wouldnt charge with both the old and the new chargers.
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
If you have tried both adapter to swap as well as the battery the problem might be with you MOBO or mother board try to flush the bios first or get the latest bios update of you system .
ERNZ
Posted on Feb 03, 2010
Acer 4830 battery suddenly dead
Your battery is still alive, the problem is in the laptop, it may have a blown resistor or charging ic. I can bypass these parts tru jumpering if ever these parts are not available in the electronics store. Now, take the laptop in the computer repair shop nearest you for this is a hardware related problem.
Feb 01, 2014 | Acer Aspire Timelinex 4830t6443 Core I3...
Acer aspire 5750 charging problem
The solution to your problem lies in one of the following three areas:
Your charger is faulty and is therefore not able to pass power to your laptops battery.
The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
Your battery is faulty.
If you are sure that your laptop charger is dead and you are in the market for a new one, try the following one:
Replacement Acer Aspire 5750 AC Adapter 90Watt 19V 4.74A
Oct 30, 2012 | Computers & Internet
My cauzin Got Acer Aspire 5920 !! its charger stop working she buy another charger for it !! but due to inexperience she bought 24 volts instead of 18 volts !! after charging some time the laptop isn't...
Putting too much voltage into your laptop will cause a strain on the power regulating components and cause them eventually to fail and then you will have a dead motherboard.
Feb 22, 2011 | Acer Computers & Internet
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Hi I have a acer aspire 5720 laptop had it about 1 year the orange light on the front which shows battery charging started to flash and when I moved the charger wire it flashes on and off I bought another...
Usually when you see this flashinf indicator it is a failing battery. IT maybe that some of the cells in the battery are failing and refusing to accept a charge, in that case the battery will actually damage the charger.
May 21, 2010 | Acer Aspire 5720 6497 Laptop
My Acer Aspire 5600 has periodic charging problem. Will charge up OK when switched off. When switched on, after a while the battery indicator changes from green to amber and then starts flashing. Then the...
I guess your charger has very low power (low wattage). That is why it charges the battery when the laptop is off. But as soon as the laptop is on, the charger can't keep up with the power dreained by keeping the laptop on and eventually the battery runs outr of juice.
According to the user's manual (http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5600_3680_UG.pdf)
I suggest you get a charger with at least 90 W.
Mar 25, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
The ac adapter for my Acer laptop has a continual beep in it and is no longer charging the battery.
Remove the laptop battery / plug in to mains, if beeping has stopped, faulty battery. If not then charger or mains faulty.
Feb 08, 2010 | Acer Aspire 6920 Notebook PC
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Hi, please help me regarding on my problem in my acer aspire 5710.. While I was using it I heard a beep tone that it was low on power and save my documents, things i have been doing after a while after I...
Does this happen a lot that you let it die when it has low power? This can damage the computers internal software for such operations, it is meant to be turned off through the off button under start etc. Try keeping it off of power, meaning take out the battery and the plug and leave it sitting for a cuple hours this should reset the system, it might help. Other than that I do not know, go to a local computer fixer persoN! !!
Aug 11, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Travelmate 270 - battery problem?
IT sounds like your laptop or powersupply/charger is at fault. Try to use a different charger, and if possible use your battery in a different computer. That way you can narrow down where the problem is. It might ba a faulty connection where the charger is connected to your computer. To check this out, try running the computer on AC without the battery installed. If it suddenly shuts off it's a problem with your powersupply or possibly the connection plug in the cimputer.
Apr 24, 2007 | Acer TravelMate 270XV Notebook
Acer Aspire 5920-6335 Laptop Logo
230 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
