Question about Sharp EL-531VB Calculator
How do you use the statistics function to find out the mean?
  • Sharp Master
  • 7,993 Answers
Press [2ndF][MODE][1] to select single variable statistics.
  1. Enter a value and press [DATA]
  2. or enter value, press [X,Y]key, enter the frequency then press [DATA
When finished you can access the mean (xbar an X with a small horizontal bar like a minus sign on top of it.)
The xbar may be a key accessed directly if xbar symbol is on top of the key, or a [2ndF] key if xbar is written on the body of the calculator.
Posted on Feb 03, 2010
How do you find the standard deviation using the list function when you place values in two lists? (Casio fx-9750GII)
It depends what the two list mean.
If you are doing 1-var statistics you may want to enter the frequency of a data element (if some are repeated) in the list L2.
In that case when you run the CALC 1-Var , you first press the F6 key to set the lists Data List1, and Frequency List 2.
Once you set the lists, press the F1 key to select 1-var. The calculator will give all the statistics of the distribution.
If you are doing 2-var stats SET the lists and press F2 2-var. The calculator will give you the x-statistics, followed by the y-statistics.
Sep 17, 2011 | Casio FX9750GII Graphic Calculator
How to solve mean, variance and standard deviation on the ti 83
get the TI 84 for dummies book, and check the statistic functions - they are fantastic - got me an A in statistics - once you start using them, you must practice- a function for everything!!
Jan 29, 2011 | Texas Instruments TI-83 Plus Calculator
Hod do you put this calculator into statistical mode?
The 30XA doesn't have a statistical mode; all of the statistical functions are available at all times.
2nd [CSR] clears the statistical registers, Sigma+ adds a data point, Sigma- deletes a data point, 2nd [x-bar] gives the mean, 2nd [sigma-x-n] and 2nd [sigma-x-n-minus-one] give the population and sample standard deviation.
For full details, refer to the statistics section in the manual. If you don't have a manual, you can download a guidebook from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti30xa.html?bid=6
Jan 08, 2011 | Texas Instruments TI-30XA Calculator
How to solye statistics problem
I have no clear idea what you mean by solve statistics problem. But if your problems involve finding the standard deviation and other statistical values then this post will help you.
The variance is the square of the standard variation
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Dec 22, 2010 | Casio FX-115ES Scientific Calculator
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
Create a scatter plot of the data
The drawing of the scatter plot proper is explained in the last part (Part F). You might want to jump right to it.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. TO CLEAR OLD DATA
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. RUN the SETUP EDITOR Command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. TURN DIAGNOSTICSON option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DIAGNOSTICSON option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DIAGNOSTICSON
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. ENTER THE DATA
Press [STAT][1:Edit]
Type in your D (X ) values in L1 and the N (Y) values in L2 (see picture 1). Sorry the picture does not have YOUR values.
TO OBTAIN statistical RESULTS (optional)
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (THESE~ARE NOT YOUR RESULTS). Your results will be different.
Notice the Down Arrow next to n=7. That means the results screen has more values. Press the Down Arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the statistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have To perform a regression analysis.
E. PERFORM A REGRESSION ANALYSIS
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. Select Regression model (Example Exponential, linear, sine, quadratic, etc.) Here I selected Exponential
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [0:ExpReg]
  3. The command ExpReg echoes on main calculator screen.
  4. If you press [ENTER] you will get your equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While ExpReg command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have ExpReg Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results. (These are your actual results)
You also have r and its square.
Since the equation is saved in the Y1 function it can be superposed on the scatter plot. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
F. DRAWING THE SCATTER PLOT AND BEST FIT CURVE ON SAME SCREEN
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] and press ENTER to open plot1 configuration screen
  3. Use arrow to highlight On and press ENTER
  4. Use the Down Arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the XLIST is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearance of the raw data point.
And here are your two graphs: the raw data scatter plot and the line of best fit on the same screen. On the picture the ZoomStat option was used.
Now, it is up to you to accept this model or to try another model.
Nov 06, 2010 | Texas Instruments TI-84 Plus Calculator
How to find the mean on the calculator
Press SHIFT x^2 to use the mean function.
Refer to the "One-Variable Statistics" section in the manual (page 9).
Aug 28, 2010 | Texas Instruments TI-30XA Calculator
Finding the mean of a list of variables
Use the mean() function in the MATH/Statistics menu to find the mean of a list. For example, mean({1,2,3,4,5}) will produce 3. Likewise, if the list {1,2,3,4,5} is stored in the variable z, mean(z) will also produce 3. You can also specify a second argument to mean() to specify a frequency list for groupd statistics.
For full details, refer to the "Statistics and Data Plots" chapter in the guidebook. If you've misplaced your guidebook, you can download a copy from http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=17
Aug 03, 2010 | Texas Instruments TI-89 Calculator
Zoom auto is lined out
This means that the option is not available in the context of the calculation you are performing. You have quite a few other Zooming functions.
Apr 29, 2010 | Casio ClassPad 300 Calculator
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Sharp EL-531VB Calculator Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
