Question about HP Photosmart 4180 All-in-One Printer
Takes more than one paper from paper tray getting jammed often
    President:
  • HP Master
  • 2,017 Answers
When you inserting the paper make sure paper is dry and not stcik to another just shake the bundle and suffel it then insert and one more thing when you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
How do I fix the error of ricoh3350 where it gives me error jamming at the first tray and there is no paper .when Chang the tray it gives the same .
check paper path rather than just the paper tray.
Check duplexer and any other paths the paper takes
There will be levers of some kind to open path of path through the printer .
Mar 11, 2017 | The Office Equipment & Supplies
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
The paper jammed and can't get the paper out.
Turn your printer off, take out cartridge and paper tray and open all access points to your printer look inside with a light it takes only a small amount of paper to make your printer have this error. Do not use any sharp objects to remove the paper as this can damage your fuser if you do have paper jammed some times using a can of air or something to blow the printer out may release it. If you still have paper jam after turning printer back on I suggest taking it to a certified technichan who can dismantle the printer to remove paper jam for you.
Jun 04, 2010 | HP LaserJet 1320 Printer
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Paper Jamming
The problem with your printer is likely to be dust getting the way of your sensors; preventing it from seeing paper, preventing the rollers from effectively feeding the paper. This is if you are sure all other things are in proper working condition. Just get a long reach brush and try to reach in as far as possible and brush as best as you could, front and back is there is access.
Sep 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Constant paper jams. Paper gets stuck. Takes more than one piece of paper at a time.
needs servicing of paper pickup roller and pad separation. Open the paper tray and check for paper dust on pickup rollers Clean the rollers and separation that is fixed in the tray itself using damp cloth. hope this will help
Feb 05, 2008 | Lexmark E238 Laser Printer
False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 14, 2007 | HP LaserJet 2420 Printer
HP Photosmart 4180 All-in-One Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
