Question about HP DeskJet D2560 InkJet Printer
Hp printer not working - HP DeskJet D2560 InkJet Printer
    President:
  • HP Master
  • 2,022 Answers
There are many possibilities you not mention the error I m giving you the entire possible thing to check and get problem resolved by one.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Make sure the cartridges are not dry and they are working fine and there is no paper jam inside printer.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Just remove the cartridge and clean it and reinstall it problem is still there replace the cartridge
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
i hope it will resolve .
Have a nice day and do not forget to rate please...!
Posted on Feb 03, 2010
    Problem Solver:
  • 5 Answers
Check cable power and turn on. to test print withaut computer, turn on-hold switch with open close cover as 3times. if ok, printer meaning good. so conect your print n comp.. gdlck. joko-indonesia
CAN IT WORK WITH APPLE COMPUTER ?
Here is a list of HP Printers that works with Apple MAC http://www.hp.com/sbso/printing/mac/
if you are wondering if a specific model works with Apple,then kindly provide the model number of
that HP printer and I'll check it up for you.Thank You.
Nov 07, 2010 | HP Office Equipment & Supplies
HP 1010 Laserjet drivers in windows 7 support
try going to the hp web site and downloading the correct driver for the printer
when finished , right click on the printer , click on the compatibility tab and tick box , highlight win 7, apply and ok
Apr 04, 2017 | HP Computers & Internet
My HP Printer Deskjet 3320 is not working with Windows Vista
You can follow Hp's Installing and Configuring an Alternate Driver in Windows Vista. Click this link provided by HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&cc=us&lang=en&dlc=en&product=75035
Before you follow though with Hp's alternet driver site. Please run windows update for Vista un till no updates are left. If your printer still fails to run correctly than try HP's alternate drive.
Good luck & kind regaurds..
Mar 08, 2008 | HP DeskJet 3320 InkJet Printer
Installing hp 1315 all in one printer to window vista pc
I partually solve my problem in vista. to scan I ues paint and use the scanner connection in there.
Dec 04, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printer won´t work
hp provides a line of wireless printers and sometime printer won't print with wireless...so here is what you may have to do in order to het this fixed
1. make sure your wireless password
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with hp Printer Tech Support
3.. now type the right password and try to print it
ihope this may help you
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Printer won´t work
The printers listed in here are older models. If you have purchased a printer in the last 2 years, your printer most likely will work with a print server. If your printer is not mentioned in this FAQ, it may work. If you are using a multi-function printer, only the printing function will work through the print server. Several kinds of printers are not supported on a network. These include host-based (sometimes referred to as GDI printers), and PPA printers. There are also printers designed for home use that are not intended for support on a traditional network, but that may work in a Home PNA network. In addition, several HP Officejets are not designed for or supported on networks. Host-based (sometimes referred to as GDI printers). A printer that relies on the computer´s processor to rasterize the print job. Most host-based printers use the GDI interface built into Windows (hence the "GDI printer" term), so there is no need to convert the data to PostScript, PCL, or other printer language. Some HP Deskjet printers are PPA (Printing Performance Architecture) printers. With this new printing system, the printer handles only basic printer functions while the printer software on the computer handles the formatting. All formatting, such as color matching and correction, half-toning, edge enhancement, tone correction, and ink management, are handled by the software driver. Furthermore, some of the printers listed below may work on a network, but only when they are connected to the parallel port of a Windows computer that has the correct printer driver installed and printer sharing properly configured. Contact the support group for you specific printer for details. Hewlett-Packard PPA or host-based printers: HP Deskjet 710C printer HP Deskjet 712C printer HP Deskjet 720C printer HP Deskjet 722C printer HP Deskjet 820Cxi or 820Cse printer HP Deskjet 825C HP Deskjet 1000C printer HP Deskjet 1000Cxi printer HP Deskjet 1000Cse printer HP Original Photosmart photo printer (C3804A) HP LaserJet 3100 product HP LaserJet 1000 product family The following printers are not supported on traditional networks: HP Deskjet 900 series 930C 932C 935C 940C 950C 952C 959C HP Deskjet 800 series 810C 812C 830C 832C 840C 842C 880C 882C NOTE: HP does not recommend the use of the HP Deskjet, HP Deskjet Plus, HP Deskjet 300, 400, 500, and 600 series printers, or the HP Deskjet 850C series printers for shared, high volume printing. These printers have a low duty cycle and are not designed for high volume network printing. The models listed below are not designed or supported on networks. HP Officejet 300 HP Officejet 500 HP Officejet 600 HP Officejet 700 HP Officejet K60 HP printer/scanner/copier 370/380 HP printer/scanner/copier (HP PSC) 700/900 HP Officejet V
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
HP DeskJet D2560 InkJet Printer Logo
514 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
