Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fisher & Paykel E521TRX Ice build up in the Freezer compartment
Before this happened there was intermittently water in the Fridge compartment.
I think I know what the problem is as it happened before and watched the engineer part of the time.
It seems that the metal bit that guides the water into the 'evaporator' gets misshaped and the water does not go into the 'tube'.
I think I could have a go in sorting it if I would know how to take off the panel at the back of the freezer - without damaging anything.
Guidance would be much appreciated.
  • 2 more comments
  • gws_m Feb 03, 2010
    Many thanks for the very sound advice as to how I could possibly tackle this problem.
    However I am still unable to remove the rear panel.
    If you refer to the attached image there appear to be two holes at the top of the panel that seem to invite a screwdriver but I don't know how much force to apply.
    You suggested pulling from the bottom, but that appears to be rigid. It could be that there is still bulging ice behind it.
    Many thanks
    Geza
    Herewith the precise model no.
    I think I am slowly getting there as I think that the bottom bit can be eased off once the block of ice behind it melts.
    The top right bit is not a screw - I think its the probe for monitoring the temperature of the compartment. There is an identical one in the fridge.
    Once more thank you for dealing with this.
  • gws_m Feb 05, 2010
    Just to update you.
    I failed to take the panel off. However after the defrosting I ascertained that there is no blockage as the melted ice went straight into the evaporator. Through the vent I was also able to see that the 'guide' to the drain was still in the right place. Therefore I have no idea what was/is wrong. The timer ought to be OK.
    So it has been going since yesterday morning with no new build up of ice. Fingers crossed.
    Best wishes.
  • gws_m Feb 09, 2010
    Thanks
  • 619 Answers
There should be screws on the back panel but you will have to remove the bottom basket and icemaker. remove back panel and clear all ice from defrost drain trough and tube. Good luck.
Posted on Feb 09, 2010
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The rear panel will slide out from the bottom and will bend as you pull it out to the front. There are screws holding it in. But you may be able to access the drain without taking it out. Most are at the bottom of the rear.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Feb 03, 2010
  • 2 more comments
  • Charles T Nevin
    Charles T Nevin Feb 03, 2010
    Is that a screw head you can see on the right of the vents on the right.
    Normal
    0
    font-size:10.0pt;
    Your model number is needed for more information.
    It's usually stamped on a small tag in a visible location on your appliance.
    Refrigerator-
    Behind the lower toe kick-plate, Behind the lower crisper drawer, On the
    face frame of the refrigerator body, Inside the refrigerator of freezer on the
    left or right side wall.
  • Charles T Nevin
    Normal
    0
    font-size:10.0pt;
    Refrigerator-
  • Charles T Nevin
    Normal
    0
    font-size:10.0pt;
    The evaporator coil behind the cover on the back
    wall inside the freezer will ice up under normal conditions. Every 8 to 10
    hours for around 20 minutes the
    defrost timer (or in most newer models the electronic
    adaptive defrost control) will turn the
    defrost heater on to
    melt the built up ice. There is a
    defrost thermostat which prevents the heater from
    overheating the freezer by breaking the heater circuit when the temp reaches
    close to 32 degrees F. The entire cooling system shuts off during the defrost
    cycle and starts back when the timer advances through the cycle.
    If this ice is not melted it will continue to
    build up until the air can’t flow over the coil to circulate the cold air
    through the freezer and into the fridge. The temperature change in the fridge
    is usually noticed first followed by the freezer.
    If the defrost thermostat is bad, it can prevent the heater from
    coming on OR it won’t turn the heater off when it gets too warm. It is clamped
    to the evaporator coil at the top to sense the temp. If it appears to be
    misshapen it is bad.
    With an ohm meter it should show continuity when
    cold and none when warm.
    You can also bypass(disconnect the two wires
    plugged into it and twist them together) the thermostat to see if the heater
    comes on then. If it does then you know the thermostat is bad and needs
    replaced.
    The defrost heater is
    located on the evaporator. It is in a tube which is at the bottom and can also
    go up the sides of the evaporator. On some types you can see a burnt spot if
    it’s bad. With an ohm meter it should show continuity from end to end when
    disconnected from the wiring in the freezer. You can also test the wiring for
    voltage when it’s in the defrost mode.
    If
    you have a
    defrost
    timer
    you
    can test it. It can be located under the fridge behind the kick panel on the
    front. Some are in the fridge with the controls at the top.
    You can turn the defrost timer till it clicks and everything shuts
    down. The heater should now come on. If it does, replace the timer because that
    means the timer is not running. If it
    doesn't, check the heater and defrost thermostat. Turn the timer again till
    everything starts back up to end the defrost cycle.
    If you have an adaptive defrost control instead of a timer,
    replace it if the heater and thermostat test good. It is located in the fridge
    with the controls in some models and on the back in others. You can post your
    model number into one of several appliance parts sites on the internet and
    search for defrost components to find your parts.
  • Charles T Nevin
    Maybe you can use a hairdryer to speed up the melting. If you can find more numbers to the model number I might can find another diagram.
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
Fisher & Paykel E521T Fridge Ice Build up behind Freezer compartment. I have had my fridge for about 7 years and ever since I bought this fridge I have to defrost it every 6-8 months because water...
Have they cleaned the drain tube that runs down the back of the fridge? If not and the tube is clogged water will back up and give you the problem that you are having. The only other thing that I can think of, is that the defrost cycle may not be set to a minimum amount of time to where this can be increased to allow the freezer not to let the ice build up.
Apr 19, 2017 | Fisher and Paykel Active Smart E522B...
Will ice build up in the freezer compartment of a fridge cause the it to run eratically. It runs excessicely and the thermostat doesnt seem to be working ? If so how do I defrost it safely and quickly
You probably have a bad evap sensor. It tells your fridges heater to turn on. If it's not that sensor, it might be a bad heater, or a clogged drain. Take the food out and the back off to see. On Fisher and Paykel, I would highly recommend a servicer because the machine is made in New Zealand I think, but there is definitely something wrong.
Jan 23, 2012 | Fisher and Paykel Refrigerators
Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Oct 04, 2009 | Fisher and Paykel Active Smart® E522BR...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
I have a Fisher & Paykel fridge/freezer model N500B a CFC model with the freezer below the fridge. We have started to get a frost biuld up at the top of the back wall of the fridge compartment. A...
using a hairdryer is ok. don't let water drip on it and don't point too close to plastics
ice build up on fridge wall can be due to:
short of gas
partial blockage in sealed system
compressor starting to fail
stat switchback temp wrong
insulation failure
Sep 30, 2008 | Refrigerators
Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Aug 25, 2008 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
714 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
