Question about Saeco Magic De Luxe Espresso Machine
The reservoir is leeking water - Saeco Magic De Luxe Espresso Machine
  • 1,089 Answers
Hi There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it need’s to be replaced. Clean any residue inside the opening with a Q-tip. When you get the new seal, it won’t slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
Posted on Feb 04, 2010
Vehicle is losing water. Already changed water pump. Unsuccessful at resolving issue.
are the carpets in side dry might be leeking from heating unit cylinder head jackets leeking you would see the water running down the sides of the engine split hoses leek in radiator or expansion tank hoses how much does it lose has the mechanic done a pressure test there could be a crack in the block or cylinder head a pressure test would find all these leeks
Mar 26, 2015 | 2003 Buick Regal - Supercharged 3.8L V6 -...
I have a spacemaker that leeks at resover
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
Dec 30, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
Water in car
I suggest taking a garden hose and have someone spray your car while you are inside finding the leek stop the leek first .Take a house fan and an extention cord out to car, let fan blow on wet area until dry. another idea is to use a hair dryer. If you dont stop leek you will have a mold problem in no time. If this was helpful please leave good feedback.
Jun 28, 2013 | Cars & Trucks
Leeking water
when ac runs, thats water coming out is from the humidity pulled out of the air
Jul 28, 2012 | Dometic Rooftop RV Air Conditioner
MAYTAG REFRIGERATOR LEEKING WATER
Have you checked and cleared the drain in the bottom at the back?
Mar 26, 2012 | Maytag Refrigerators
Leeking coolant
Check the reservoir/tank. Expect to replace the tank at a tune of 300 plus dollars.
Aug 02, 2011 | 2005 Jaguar X-Type
WINDSHIELD FLUID LEEKS OUT WHEN FILLED
find a used washer reservoir on eBay. replace yours with that one and use all new hoses.
Feb 01, 2011 | 1999 Ford Expedition
Power steering fluid leeking beneath steering. how do i fix?
Either the shaft seal on the pump has failed or the fluid reservoir is cracked; the latter seems common on Chrysler products.
If you decide to DIY, you may notice when shopping the pump that the reservoir is sold separately by mos vendors.
Aug 19, 2010 | 1999 Dodge Caravan
Added coolant and tank is full. Ran it a couple times and added more coolant. 1 1/2 gallons altogether. Coolant light goes out then comes back on in a few seconds. Do these systems need bled. Has a bleed...
Good Evening. Bleeding the air out of the cooling system is a very important step. What you are looking for is just a steady stream of antifreeze you will see the difference from the flow with air an just fluid. Once you do that top off your reservoir and you should be just fine. Hope this helps, and if you have any more questions please feel free to ask.
Aug 14, 2010 | 1997 Oldsmobile Achieva
Saeco Magic De Luxe Espresso Machine Logo
46 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
