Question about Ovens
White powdery stuff inside the oven, now no heat
I used my blanco (basically brand new) wall oven tonight to keep some meat warm and when I took it out there was white powdery stuff all over the inside of the oven. It now won't heat up, although the grill element is working. Is it the oven element or bigger problems? Thanks.
  • Ovens Master
  • 3,463 Answers
It sounds like the oven element has blown.
The powdery stuff you refer to is the insulation of the element that has blown out.
You will have to fit a new element.
Please rate my solution.
Thankyou.
Posted on Feb 03, 2010
Testimonial: "Thankyou, great help!"
Find the model number on a 2010 Blanco stainless steel wall oven
The number has to be somewhere on the unit. Find it.
Nov 22, 2015 | Blanco Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Apr 07, 2011 | Ovens
The bottom heating element in an electric oven exploded as I was cooking pork chops. White stuff got all over the oven. Is it safe to eat the pork?
i would not trust it there is chemicals inside the heating element along with metal particals that you can get in your food... sorry ,but better eat out tonight.... good luck to you...
Jan 12, 2011 | Ovens
How do I remove the hinges from a Blanco BOS402
slide the oven out from the wall. You should be able to remove the hinge from the side.
Sep 13, 2009 | Ovens
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
BLANCO Stove Not heating up
Resolved, I took the fan cover off and the round elementjust fell apart, so I'll get a new element and all should be OK.
Regadrsd,
john S.
Jun 18, 2009 | Stoves Ovens
Broiling
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
271 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
