Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Wrte protected, Formatting is not possible. But it s working. No save no copy and deleletion.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 28 Answers
Maybe it has a virus...
try to format it using command prompt...
do you know how to use command prompt??
if not email me at stormblade002@yahoo.com
Posted on Feb 03, 2010
I want to copy music folders to the 8gb sahara usb flash drive but is saying I cant is the drive is protected
click start all programs accessories open windows explorer navigate to your music files right click on the music right copy navigate back to the destination drive right click select paste or hold the
mouse cursor on the music files drag them to folder
then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another
device floppy or a usb device
if you need more help with this post a reply
hope this helps
Apr 25, 2012 | Computers & Internet
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
Problem with section numbers not being linked in a word document that I'm updating using word 2007. The original document was created with an earlier version of Microsoft word.
When you create or open and edit a (.docx) document in Microsoft Word 2007, the Save As option gives you the opportunity to save it as a the (.doc) document in the formats of older versions of Word.
If it is not already too late, try to recover (using the AutoRecovery function built-into Microsoft Word 2007) , the earliest and most error-free version of the document in question you can recover and then use Save As, rather than Save to make an experimental copy of the document in an older Microsoft Word format.
Another option to consider is to download and install the free Office Suite Application Open Office, which can open, edit and manage many Microsoft Office documents and then copy and paste the most error-free version of the document in question into the appropriate Open Office Program and then see what sort of job the Open Office Word Processor makes of handling the tricky formatting.
For the future, as a general rule, whenever editing any document that contains complex formatting, always remember to start by copying and pasting the text of the original document into a new blank document (remembering to close the original document so you don't accidentally toggle between the two). Then your experiments could be conducted on a copy of the document, rather than the original, enabling you to repeat the method and continue creating experimental copies freely, until you have developed a workable strategy for dealing with the formatting issues.
Furthermore, remember to always use the Save As function, giving the experimental documents distinct and varying names (test.doc1, test.doc2, test.doc3 etc.) so you can keep track of your progress in mastering the formatting issues, then each document you save, is a copy, leaving the original document unchanged and available as a template for further experimentation, if necessary.
Nov 26, 2011 | Microsoft Office Professional 2007 Full...
How do I remove "write protection" from Word files
  1. Open Word, and open the protected document. Click on the "Developer" tab.
  2. Click on "Protect Document" tab, and then click on "Restrict Formatting and Editing."
  3. Click on "Stop Protection."
  4. Type the password into the password box.
If you have forgotten the password, copy and paste the information from the write-protected Word document into a new Word document, and then save it under a different name.
I do this for fun & 4 thumb feed back, not $$$$
Jim
Oct 04, 2011 | HP Computers & Internet
How do I get to formatting so I can delelet all photos on card
Press the MENU button. Choose [Set up] and press the OK button. Use the cursor arrows to select "Format memory/Format card" and press OK. Follow the on-screen prompts.
Jul 30, 2011 | Nikon COOLPIX L10 Digital Camera
I added a 2gh memeroy card and don't know if it has to be formatted to the camera or do i just start shooting photo's and it will automatically go on the card?
Yes format your memory card for sure I'm also sending a diagram of an SD card showing the little switch on the side. This switch locks the card from formatting to protect or save images.
Also the formatting of the memory card allows the camera and memory card to communicate properly between the two. Formatting should be done after each time you download pictures to the computer Formatting should be done in the camera the memory card is being used in not the computer.
Here is the diagram.
Jan 14, 2011 | Polaroid a540 Digital Camera
Cannot upload pictures from a cd
make sure this disk is not "hidden" or "protected" for this is meant to lock your photos on your cd for privacy purposes. you can do this by right clicking on your "cd" drive and click properties. uncheck the correct boxes.
if this does not work also try to copy and past them into another folder. and then move the folder to the mac.
however there is quite a difference in acceptable formatting between PC's and Mac's so you might need to download a simple and free picture formatting program.
go to download.com look up TransMac 8.3 and read about it there, it might be what you need
Jul 07, 2009 | Fuji FinePix A345 Digital Camera
How can i remove write protect to card reader
wrte protection is in card media there is a switch mechanism in Card sometimes which restricts data to be written it is a latch type mech normally , u can make it writable by setting the swtich to unlock , u can not make media write protected thru card reader
kindly rate me well !
Jul 04, 2009 | Electronics - Others
Removing write protection from a memory stick
have a toshiba memory stic that is wrte protected and i dont know how to remove it.please help
Jun 13, 2008 | BUSlink MUSICA MP3-PBD1G MP3 Player
Write-Protection of Pen Drive
even i hv the same prob add me jay_ghai@yahoo.com ...
Oct 18, 2007 | Computers & Internet
Electronics - Others Logo
87 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
