Question about MLB New York Yankees Sapphire Series Crystal/Platinum Watch Mlb Baseball
Cannot switch machine on - MLB New York Yankees Sapphire Series Crystal/Platinum Watch Mlb Baseball
    President:
  • 2,501 Answers
Watches turn on when the crown wheel is pushed home.
If it does not start when you do this (try pulling it out and pushing it back in several times ), then would would seem to be a limited number of options.
If it is new, then return it to your supplier.
Get the battery checked.
Otherwise take it to a watch shop for repair.
Posted on Feb 03, 2010
Steinhausen tm-478 single watch winder how it worcks
Watch Winder Setting & Instructions for Executive Collection
Jared Tracy
posted this on March 30, 2012, 2:44 PM
  • inShare
  • There are four modes for our Executive Collection of Watch Winders (TM and SM series):
    Mode 1 (both switches with the O pressed in): rotates for 180 seconds on then 12 minutes off.
    Mode 2 (first switch with the O pressed in, second switch with the I pressed in): rotates 180 second on then 15 minutes off.
    Mode 3 (first switch with the I pressed in, second switch with the O pressed in): rotates 180 seconds on then 18 minutes off, then 180 seconds in the opposite direction.
    Mode 4 (both switches with the I pressed in): rotates 180 seconds on then 24 minutes off.
    For switching winding direction:
    I pressed in will wind clockwise
    II pressed in will wind counter clockwise
    Neither pressed in will turn the winder off
    *Please note that the CW and CCW settings do not apply when the winder is set to Mode 3 as this mode winds in both directions.
Apr 10, 2014 | Steinhausen TM-478 New Single Watch Winder...
Instrukcja pralki beko aa class 1000rpm
unplug the machine, find a good sized pan that is very low. get a wet vac ready, then get to the pump filter there should be a drain that you would use before removing the large cap. either use the small drain "less messy but time consuming" or the large one "really quick but water all over"
Aug 15, 2013 | Watches
A KD12DSS-2 KELVINATOR DISHWASHER WITH FAULTY ERROR 4 CODE
Hi.
Error 4 is internal leakage (overflow).
when this happens often the dishwasher starts with the pump running continuously.
Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
Regards.
Ginko
May 15, 2011 | Watches
I have set the 2nd time zone, but I can't set the watch to display the 2nd time zone.
Had the same problem when my niece was playing with my watch and switched time zones and I couldn't find the paperwork to switch it back. After not finding the solution online I played around with the watch and figured it out. Just hold down the start split button till it switch zones. It will beep when the switch completes.
Feb 24, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Professional battery installation, doesn't turn on, is there a power on button? Or do I need to take it back and have them try again?
There are only a few Authorized Polar Service Centers. If you did not take it to one of these (which provide a 90 day warranty) they may have broken something or put in the wrong battery.
Polar and other HRM's are mini computers and actually quite delicate inside, they are not normal watches and while many watch repair places profess to be able to fix them, more often than not they cause a new problem. They are also repressurized with a special machine to keep them watertight, your watch is most certainly not watertight anymore and will eventually cause yoiu problems.
Too answer your question, no power on switch, if the battery install was good you would see a display. Take the watch back to the shop, and if they can not fix it, send it to Polar and then have the shop reimburse you for the repair. Polar will be happy to send them a detailed and Itemized account of what they had to fix.
Dec 03, 2010 | Polar FT40 Heart Rate Monitor Watch
How to switch wave ceptor back on after fitiing new battery
Find it here:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 29, 2009 | Casio Watches
Brake light switch not meeting brake pedal
The brake light switch should be adjustable in as much as you can screw the switch holder around until it is the required distance from the brake pedal - the switch holder should have a locking nut, which requires undoing first then locking back once you have obtained satisfactory adjustment,thats assuming that the switch itself isn't broken or faulty.
Feb 10, 2009 | Beverly Hills Polo Club 22-710TTS
MLB New York Yankees Sapphire Series Crystal/Platinum Watch Mlb Baseball Logo
46 people viewed this question
Top MLB Watches Experts
Ansel Alberto
Ansel Alberto
Are you a MLB Watch Expert? Answer questions, earn points and help others
