Question about HP Photosmart C4180 All-In-One InkJet Printer
Computer has stopped recognising printer h 4580
    Problem Solver:
  • 5 Answers
Shutdown all item. check your conection cable, pull and plug again. switch on printer and check your cartridge. switch on computer look the message on display. most important check cable usb printer. goodluck,from joko-indonesia
Posted on Feb 03, 2010
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
Regarding the printer might as well try to uninstall and install the printer driver / you can also download latest driver from their support site or might as well before installation access this to windows - click start / my computer / click c drive / click on windows folder / find system 32 click on it / click spool folder / you will see 3 folders / click on drivers / rename folder w32x86 to w32x86.old as well as click on prtprocs and rename folder w32x86 to w32x86.old and then restart and then install the new printer driver which is downloaded from your support site .
ERNZ
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
How do you remove/open printer to take out cartridge on hp 4580 printer
Access the manufacturer's web-site: http://support.hp.com
Enter: 4580
and do the search.
Choose from:
» HP Deskjet F4580 All-in-One Printer » HP Officejet J4580 All-in-One Printer » HP Photosmart C4580 All-in-One Printer and read the online documentation for the specific model. It will describe the exact steps.
Jul 12, 2011 | Computers & Internet
Why won't my HP Photosmart 4580 printer print Word documents from my MacBook?
Check the drivers that are installed on your computer printers normally have 2 sets of drivers 1 for PC type computers and 1 for Mac computers.
Let me know if this was helpful.
Sep 18, 2010 | Office Equipment & Supplies
Hp 4580 won't scan. prints & copies ok
1. did you install the software to the computer?
2. what is the OS of the computer?
3. how is the printer connected to the computer?
4. are you trying to scan from the printer or from the computer?
5. are you getting an error messages when you tried to scan?
Aug 22, 2010 | HP Photosmart C4580 All-in-One InkJet...
Users Manual for HP 4580 All-in-one Printer. How
Please download the user manual from this link
static.tigerdirect.com/pdf/HP-Officejet-J4580-Printer-Manual.pdf
Hope this information will help you
thank you
Oct 02, 2009 | HP Computers & Internet
Hp4580 not recognised on XP 64 bit
Try changing USB cable. Your USB cable might have got corrupted.
May 26, 2009 | HP J4680 Office Jet All-In-One Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
The computer will not recognize the printer My problem is similar I have a new all in one Hp Officejet 4580 and the computer that I want to use it on is running Xp service pack 3 .I have connected the usb...
hi!
if u already installed the driver remove it. Don't power on the printer install the driver . at the time of installation the software will tell you plz power on the printer or connect the printer. then you switch on the printer & connect the usb with your pc.i hope it will work for u.
if not solved change the usb cable and try again.
Jan 30, 2009 | Office Equipment & Supplies
Lexmark 4580
pls format you pc then checked
May 30, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
189 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
