Question about Hoover Washing Machines
On a quatro 1400 can I just use the cold fill only
  • Hoover Master
  • 3,463 Answers
If there are 2 inlet valves at the rear of the washer, it is meant to be connected to hot and cold supply.
However, if you just wish to cold fill only, then you can fit a Y piece to the cold supply tap, and connect both hoses to this, and then to the washer.
Then whatever prog you select, it will fill with cold water.
You can get a Y piece from B&Q or some place like that.
Please rate my solution.
Thankyou.
Posted on Feb 03, 2010
I have a Audi S6 2001 model V8 Quatro. Can not find the gearbox dip stick or any place to add ATF oil.
No dipstick on those Audi (ZF) transmission.
Put car with cold engine on hoist, engine running, someone shifting through gears.
At the same time, remove the large drain plug (17mm Allen IIRC), then pump transmission fluid in (need to fiddle the hose all the into the slot inside the hole) in until it starts running out.
Put plug back in.
Only way.
The hotter the transmission, the less fluid you can fill. Official transmission fluid temp is 40 degrees C (use VCDS to monitor temperature if you think it might be too hot). But generally better results at lower temps (not FREEZING cold, but 20-40 C (60-100 F) works better.
Jul 04, 2017 | Audi S6 Cars & Trucks
What is the yellow light on tt quatro oil sensor?
The yellow light oil sensor on Audi TT Quattro is the warning message for the minimum oil level has been reached !!!
Check engine oil level by dipstick & fill up oil inside engine !!!
Jan 22, 2011 | 2000 Audi TT
I've put some info on the thumb drive with an older program (word perfect quarto ten) and my new computer wont read the info, it comes up encrypted.how do i get my info?
You will need to have the same program Quatro on teh new computer to read it. The format is probably proprietary to the Quatro program.
Your new machine, if Vista, MAY NOT even be capable of running Quatro.
Nov 10, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Where do I fill the transmission fluid in an Audi A4 3.0 Quatro?
go to audiworld.com/tech/misc32.shtml. it is a slideshow breakdown of how to access the fill and drain holes on your audi. It tells what tool to use and how to do the work, good luck.
Aug 30, 2009 | 1997 Audi A4
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
How do i change transmission fluid on audi a4 1.8t 1997?
Drain fluid with drain plug on bottom of pan.Remove pan and change filter. Reinstall pan with new gasket torque to factory spec.Have car on level ground.Remove fill plug on side of pan.Install new fluid with pump and hose. You can use old gear oil bottle and hose.Fill to bottom of fill hole. Put foot on brake with car running shift though all gears.Go back to fill plug and top off till it runs out hole.This should do it.
Jun 11, 2009 | 1997 Audi A4
How to fill the tranny oil in 97 Audi A4 Quatro
You have to refill it using a small funel through the dipstick hole. Thats how it's been for years. I wish they would think of a way to refill these things in some other way.
Jan 11, 2009 | 1997 Audi A4
Just want to know how to get the fasted wash as it seems to take about 1.5 hrs to do a load. zanussi xc6 1400
Check your screens on the fill valves. This is a good time to replace the fill hoses, the last thing you need is an old one to blow. Wash warm, rinse warm, both fill valves will be open. If you only use cold water, hook both fill valves to cold water, cold water will go thru the hot fill valve for a faster fill.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
