Question about Siemens HB77L55GB 900 Watts Convection / Microwave Oven
My little girl ripped off the door. I basically need a new door, hinges and someone to fix it.
Will not run unless hold door closed at bottom
First, replace the hinges. If that doesn't fix it, replace the door. Someone has leaned on the door and sprung either the door, or the hinges.
Nov 25, 2015 | Microwave Ovens
Door came off. Can it be repaired?
perhaps someone that welds could fix it . should have done something a year ago
Jun 11, 2015 | Panasonic NN-SD797S Microwave Oven
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Apr 01, 2015 | Frigidaire Microwave Ovens
Replacing door on Whirlpool GH4184XSS1
The top hinge pin has narrower diameter to lock the pin to the door. Just lift the door and relieve the pin and pull it straight up, you may have to jiggle it a little bit to get it loose, no need for heavy force it will just loosens when it is in right position.
Sep 17, 2012 | Whirlpool MH7140XF Microwave Oven
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Aug 10, 2007 | Sharp R-1610 Microwave Oven
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Siemens HB77L55GB 900 Watts Convection / Microwave Oven Logo
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
