Question about Dmm Box Telescience Astronomical Telescope 25/50 40mm
No instruction manual for telescope
I have a ''Telescience'' telescope f/900mm D-60 but there is no instructions on how to put it together.
Help!
Need a manual for a 60 mm refractor telescope. Can you email me one? I purchased it through Amazon
alignment of the optics are critical. refractor telescopes refract light linearly as opposed to reflector scopes, which bounce light from mirror to mirror.
Sounds like you may have an obstruction blocking the passage of light.
Dec 27, 2014 | Optics
I need the instructions on how to put a Simmons 600 power / 60 mm telescope together because I have never put a telescope together.
You will not find a manual for that telescope brand. However Meade telescopes has a web site with all of their telescopes--
They all assemble and are used in a similar fashion:
Try these two web site links and look under the REFRACTOR heading for a scope that looks similar to your scope.
http://www.meade.com/manuals/index.html main page
This might be similar to your scope?
http://www.meade.com/manuals/TelescopeManuals/Refractors/90AZ-ADR.pdf
May 18, 2011 | Edu-Science (10166) Telescope
I have found a tasco 450 power astronomical reflector telescope D=4.5 F=900mm coated optics model no 11TR.it is missing some parts so i need a parts manual to find out what is missing.
All of Tasco's manuals are here:
http://www.tasco.com/pages/instruction-manuals/
and the repair site is here:
http://www.tasco.com/pages/repair-and-warranty/
Jan 03, 2011 | Tasco Optics
Hi I have been given a telescope but no assembly instructions and the only markings on it are "Atlas Explorer" & "D=60MM F=900MM Coated Optics Made in China" Would you know where I...
That is NOT an Atlas EQ-G as your question indicates -- this is an atlas eq-g-
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-atlas-eq-g-computerized-goto-telescope-mount
This is a 60mm refractor style telescope imported from China. No one will have a manual for that scope. Try to locate a local Astronomy club and the members will help you assemble it.
Nov 20, 2010 | Orion Atlas 8 EQ-G Telescope
I was given this telescope without an instruction manual and I really have no clue how to use it. I've palyed around a little but not really sure how to get the full benefit of the telscope. Is there any...
This is a small 60mm refractor a very simple telescope. Not much bigger than a pair of 10x50mm binoculars.
Objects in the night sky are very tiny and many are very dim. You must learn the night sky. Buy several good books like "turn Left at Orion", or "Nightwatch".
Sep 20, 2010 | Galileo GM-EQSC 900mm x 60mm astronomical...
I BOUGHT A POLARIS BY MEADE MODEL-114EQ-A,
All of Meade's manuals are located on this web site:
Look at the above page and download a manual.
Jun 23, 2010 | Meade Polaris 114EQ-D (36 x 114mm)...
Acquired a used Parks Astronomical Telescope 60 mm - 700 mm. w/90degree eyepiece is a G.S-7 5mm. My 9yr old grandson (a future engineer) decided he wanted to know how it was put together and while I...
Just found your posting kind of old but I hope this helps you--
Most of these small refractors assemble the same way-- so take a look at these Meade brand refractor manual and see if it helps you put it back together.
http://www.meade.com/manuals/TelescopeManuals/Refractors/Meade-RB60.pdf
Feb 18, 2009 | Celestron PowerSeeker 60 Astronomical...
Dmm Box Telescience Astronomical Telescope 25/50 40mm Logo
185 people viewed this question
Top Dmm Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Dmm Toy Expert? Answer questions, earn points and help others
