Question about Samsung Office Equipment & Supplies
I have a clx 3160fn printer and it does not pik up the paper it shows a paper jam in sted can any body help
No I have not yet fixt the problem I have tacken the printer to a repair shop were I hat to pay $50.00 up front they asct me to come at 3 o;clckin the after noon and the talled me there is somesing wrong with softwere and they have order it in from samsung they said the pikup shaft did only half a turn sted a full turn that takes a few days and they will let me know when to pick it up when I have it back I will let you know how things went kip you postet Matt
Posted on Feb 05, 2010
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Paper keeps jamming on Samsung CLX-3160 FN. How do I prevent this from happening?
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Oct 04, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
Paper jam
Probley not but i think you may be able to extend you warantee if they will let you so they can fix the senser or what ever is casing it to do that.
Jul 07, 2009 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN Paper Jam when there is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Paper Miss match
Please select printers and see the properties and there will be a d efault paper size which may be lette A3 etc selecrt it to your desired paper size in the settings Ok.
Mar 05, 2008 | Samsung CLX 3160fn All-In-One Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
