F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
You saved me a fortune! Thanks!!!
Brilliant machine is washing away nicely again .
I've removed the hose and it took me a while to understand that the filter is a floating ball but after removing heavy waste caught in my girl hair pins error indication disappear and the machine started to work again.
Amazing tip many thanks.
Tsafrir, Israel
SOURCE: indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
SOURCE: error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
