my razr screen is blank. on the outside & inside.
i can turn it on, make calls, recieve calls, everything.
but i cannot see. i read that i should hold * and #,
but this does nothing. i also read that if that doesn't
work then it must be the flex cables.
if that is the problem, can this be fixed? and how?
My razr is retarded. The screen is all white and blank, but the phone itself still works but you just can't see anything. I read that if you turn it on its side and bang on it that the screen will turn back on...I did that but all it does is it tries to load the screen and it gets all these thick red lines across it, and then it goes blank again. Any help?
My screen just completely went out too. I've never heard of those problem solvers above^ so I'll give them a try :/
-   My Razr's screen turns black both inside and outside the buttons light up.. and i can make calls and recieve calls but i just can't see anything! im so frustrated. this is my 4th one this year and never dropped but they all have the same thing.. -   Guest
Feb 13, 2009
-   this little silver thing fell out the side where i guess the hinge is supposed to be. ever since, my screen has been blank. on top of that nothing is saved to my SIM. is there a way i can navigate around and get everything saved to the SIM?
-   lynne31
Feb 10, 2009
-   my screen goes white, but i can make calls-   Guest
Dec 24, 2008
-   I have a Motorola V3M phone and just got it turned on Dec 20 2008 at a Cricket store and the next day when i went Christmas shopping my outside and inside screen went blank. I was able to shut off phone and got back my screen but after a few minutes it did it again.Never dropped it or anything. I called E-Bay, that's where my boyfriend bought this phone for me. So I called and the gal I talked to said it may be the battery and they are going to mail me another different battery today but not the same kind of battery but I won't get it untill 7~10 days! But I'm wondering has any one replaced their battery on their Motorola V3M phone and did it help get rid of the blank screen and blank front screen? Thanks E. -   Guest
May 11, 2008
-   my krzr is doing that too. The front of my phone has like a mirror but its all cracked. It was working fine that way but then a few days later it just turn to white screen like 10 times a day. Now the phone works, i can make call and recieve calls but i cant see it. So i guess i cant see whn i text, take pics, and stuff.-   Guest
this happens either when u r razr was dropped or have gotten wet...If it fell u need to remove the four screws on the screen and pry the cover off with a possibly thin knife.The flex cable is located at the top left hand side of the screen. you need to take this off and reseat it again.try powering on the phone before u close it back again to ensure that it works.If this doesn't work either your screen or flex cable is gone, then u need to check a phone repair shop.you need either a t6 or a t4 screw driver set to remove the four screws located under the the 4 rubber fillers on the inner screen.
sam !
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Apr 08, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My motorola Krzr's screen was dark on the inside. All i did was take the battery out for a few seconds, put it back in and now my screen works fine...for now anyways...
Hi Friends, Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3is hardware problem.Such as won't charge, black screenetc. For solution of thesehardware problem justclick here. For any other problem of Motorola RAZR V3 like software problemor other justclick here.
I have a Motorola RAZR v3m, and whenever it is on from anywhere between 2 and 5 minutes, the screen...
(More)
I have a Motorola RAZR v3m, and whenever it is on from anywhere between 2 and 5 minutes, the screen will turn white, and then it will return to normal, but the only difference is that the keypad doesn't work at all. The only way to get the phone to work again is to remove and reinsert the battery. I have done that about 10 times now, but each time I do, the same thing happens again.
I have a sprint lg rumor and need to know how to down load my photos from this cell phone to my...
(More)
I have a sprint lg rumor and need to know how to down load my photos from this cell phone to my computer.
