Question about Sprint Palm Centro Smartphone
Touch screen does not work. what can i do? i already did a hard reset by instruction of palm technicians. and now im really stuck
  • 63 Answers
Check to make sure you have the touch screen turned on. on my touch screen, i have the option of turning off the screen so bumping it does not cause it to do things i don't want done.......
Posted on Feb 03, 2010
Touch screen did not work
I write this tip for Palm Pda's but it is valid for many other brands of pda's and phones.
First things to try is a normal reset and then a hard reset.
To do a normal reset, press on the reset button on your handheld.
Hard reset is performed differently on different models, check palm website for hard reset instructions: CLICK HERE FOR PALM RESET INFO PAGE
if the touchscreen doesn't work at all, and you can't align or calibrate it, or it presses on wrong spots even after calibrating many times, digitizer (which is the touch part on top of the lcd display) is most likely broken and would need to be replaced. On rare cases reattaching digitizer cable and making sure that the digitizer is clean and intact and properly on its position may solve the issue.
If you are inside warranty the repair may be completely free, contact your dealer or palm.
Outside of warranty, you have 3 options.
  1. Replace digitizer yourself, you can find a replacement from ebay.
  2. Send it to palm for out of warranty repairs, probably around 100usd.
  3. Take it to a local professional who can replace digitizer for you.
Thanks, let me know if you have any questions and good luck.
Ekse
Note: In some phones the digitizer may be connected into the lcd in away that it can't be easily replaced. In these cases You will have to replace the whole screen. if the touch is non responsive after the replacement, the issue could be with the connector or then you have a faulty main board.
thanks
Jul 07, 2010 | Sony Ericsson P990i Cellular Phone
Touch screen not working I have reset but screen not working
u have to go any repairing shop n show it then they will set its chip which is internaly connected with ur palm
May 10, 2010 | Palm Zire 31 Handheld
Touch screen on Palm Z22 does not respond
The Data on your Z22 is rock-solid safe, but unlike the answer that states to do a RESET- DO NOT ! The touch screen problem has nothing to do with resetting, it is a failure of the soft plastic top layer of the touch screen. There is a tiny, remote possibility that the logic circuits are out of sync and the touchscreen really is mixed up in a software state, and a SOFT RESET may reset the touch screen, but this is almost unheard of ( but does happen).
I have an entire page on the Z22 and how to maintain, repair and interface it. It is at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I would suggest trying a few tricks listed on my web page, and see if you can get the screen to work again. It is IMPERATIVE to get a hard plastic cover over the screen to keep it working!
Please read over the information on the Z22 page.
good luck
robin dusty graves
Z22 PALM PILOT touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg touch-screen-palm-z22-not-respond-ngl0e1lc0ft3j10pmz4xzklk-3-6.jpg
May 27, 2009 | Palm Z22 Handheld
Htc p34001 touch screen not working...........im really frustrated ...........
the touch scren not workin i can't see or do nothing on it wat should i do
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Treo 600
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus4.gif.
Jan 01, 2008 | Palm Treo 600 Handheld
Touch screen will not respond
I had the exact problem as you, and was at my wit's end and ready to throw my Zire into the trash can, but decided to give it one last ditch effort by getting in touch with Palm tech support. Boy am I glad I did, because the solution was so easy: what you need to do is hold the power button while you do the hard reset (in the back, using a paper clip), but the key to this step is to keep your finger on the power button for a full 30 seconds. When I tried this same process before, I experienced what you are experiencing, but when I help the power button on for 30 seconds, just like the tech instructed me, it worked on the very first try. It was so easy and it fixed the problem. Give it a try!
Dec 19, 2007 | Palm Zire 31 Handheld
Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Dec 11, 2007 | Palm Treo 600 Handheld
Setup
I tried everything, even heating my Palm as described here.
The only thing that really worked for me was pressing the "up" button while pressing the "Reset" button (hard reset). Luckily, I had all of my files backed up. The hard reset truly worked. Good luck to all!
Dec 05, 2007 | Palm Treo 600 Handheld
Sprint Palm Centro Smartphone Logo
139 people viewed this question
Top Sprint Computers & Internet Experts
Computer Repairing
Computer Repairing
matt
matt
Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
