Question about Cooktops
Oven dont turn on ihave checked the braker is ok
  • 63 Answers
Have you turned the control knob to broil and the temp all the way up, this will check to make sure you have a good switch on your selector. then turn onto bake and turn all the way up. let me know
Posted on Feb 03, 2010
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Stuck knob
if this is a oven you are lighting would be oven thermostat would contact surplyer as faulty goods dont try repair as will void garantee
Jul 29, 2012 | Jenn-Air JGD8130 Gas Cooktop
Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
May 27, 2009 | Cooktops
GE jgp328 front ignitors won't turn off. How do I remedy this?
Did you just clean it? If the swiches under the burner knobs get wet, they cause the electrodes to click. Unplug the unit or turn off the braker for a day. it should dry up and work normal.
May 04, 2009 | GE 30 in. JGP328 Gas Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
F7 Error
This error happens if a function (key) is stuck. Usually the one that is used most often or the one that someone poked using something pointed.
Change the touch pad if it is separate from the clock (ERC or EOC) or change the whole clock if they are one unit
May 05, 2008 | Jenn-Air JED8430 Electric Cooktop
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Circuit Braker Jump Off Easily on GE JP350 Cooktop
The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
Oct 27, 2007 | Cooktops
Cooktops Logo
55 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
