Fuzzy picture wen connecting macbook to tv
Im trying to connect my macbook to my tv, i have a dvi to hdmi cable and an audio cable. wen i hook them up, the sound is good but the picture is fuzzy, any ideas?
  • chanwingjenn Feb 03, 2010
    i originally had the hdmi cable plugged into an input source which had no audio outlet and the picture was perfect but no sound, so i had to get an audio cable. i then plugged both these cables into another input and the sound came but the picture is fuzzy. if i plug back into the other input, picture is perfect, but no sound, and i cant use different input sources for sound and picture.
  • Anonymous Mar 17, 2014
    The picture is fuzzy even hooked up to cable
  • 12,061 Answers
Sounds like bad Earths to me... Is it better if it is OFF, the AC/DC power supply? If so then yes, bad earthing between units and earth.
Posted on Feb 03, 2010
  • electronic & computer repair&  servicre
    Yup well that confirm it then you are getting phasing earth imbalance.. IE: Small voltage variations between earth connections... Analogue and Digital have different "Earth" potentials. Which is why we have HDMI and it is all "in" there.. so to speak. You are going to have to try to connect the ALL the Earths all together perhaps with a separate wire joining them all up, The Negatives and Earths between the Leads. I mean. try that
I hooked up my laptop C300 to my tv. I get picture but, no sound. Do I need a sound card? If so, which one?
It all depends on how you connected to the TV. There are 3 common ways, using HDMI, DVI or a VGA cable. Of the 3, only HDMI transmits sound from the computer to the TV. If you are using DVI or VGA, you will need to connect a cable from the audio out (headphone) jack on the computer to audio in on the TV. If you are actually using a HDMI cable, it is probably a setting somewhere.
Jan 22, 2017 | Computers & Internet
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Nov 26, 2008 | LG 42LG50 42 in. LCD HDTV
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
Electro Med Services...
