Question about Brother P-Touch 1180 Label Printer
I have a P touch 55 and have lost the operating instructions. I need to know how to increase font style and select numbers or letter, or get the operating instructions if possible. Thanks
  • 742 Answers
You can download a user manual HERE.
Posted on Feb 03, 2010
How do I increase the type on my AOL emails
You will need to find the font & font size options on the AOL email system. The font will be what the letters look like and font size will be how large the letters are. Standard font and font size is Times New Roman 12 (this message is in that font and size). You can increase the font size from anywhere like 14 to 72 or so. Try 18 or 20.
Mar 30, 2011 | Computers & Internet
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
I want to change my font in MS Outlook. Now is Calibri with letters in light blue color, tough to see. I want to default to Arial and black letters. I can change to that each time I respond to a...
Select "Tools | Options..." from the menu et081706_3.png Select "Tools | Options..." from the main Outlook window's menu
Heinz Tschabitscher
  • Select Tools | Options... from the menu.
Go to the "Mail Format" tab et_default_font_outlook_1.png Click "Fonts..."
Heinz Tschabitscher
  • Go to the Mail Format tab.
  • Click Fonts... under Stationery and Fonts.
Use the "Choose Font..." buttons to select the desired font et_default_font_outlook_2.png Use the "Choose Font..." buttons to select the desired font
Heinz Tschabitscher
  • Use the Choose Font... buttons for When composing a new message:, When replying and forwarding: and When composing and reading plain text: to select the desired fonts and font styles.
  • Click OK.
    • If stationery is defined to be used by default under Use this stationery by default:, the font specified in it may override the font you have just specified. You can either choose "<None>" as the default stationery, adapt the stationery to include your favorite font make outlook ignore font specified in stationary altogether.
Make Outlook Ignore the Font Specified in StationeryTo set Outlook to ignore fonts specified in stationery and use the default instead when composing a message:
  • Make sure either Always use my fonts or Use my font when replying to and forwarding messages is selected under Stationery fonts.
  • Click OK.
  • Click OK again.
Jul 29, 2010 | Computers & Internet
For the HV #1+ embroidery unit, using the plus hoop and embroider
Hi!
You can find the solution by following these steps-
Slide in embroidery card 21 and companion cassette. Touch Embroidery ON.
Touch FUNC to Program mode, The “E” inside the hoop will appear on the left end of the Program display window. If Plus Hoop programming is desired, touch the rotational arrow E one time and you will see the hoop in the Programdisplay window change into a Plus Hoop with a small arrow pointing to the top portion of the hoop, indicating position 1.
Toward the right side of the Program display window are
F1 S1 M1. F1 = Font style (1, 2 or 3), S1 = Size (1 or 2) and M1 = Menu (1, 2 or 3).
FONT: Select 1. Palace Script 2. Clarendon (block) 3. Kalligraphia
(Note: Programmed letters are always displayed in block)
SIZE: Select 1. Large 30mm 2. Small 12mm
MENU: Select 1. Upper case, 2. Lower case, or 3. Numbers and Symbols—check Program display for upper or lower case indication.
Note: You must select the Font, Size and Menu before selecting the letter desired.
Do rate the solution accordingly.
Thanks
Rylee
Mar 16, 2009 | Husqvarna Viking 1
Brother P-Touch 1180 Label Printer Logo
702 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
