Question about Haier HLT71 7 in. Portable TV
For use during an extended power outage, where of course you wouldn't be able to recharge the battery after it drained initially, I'm wondering if anyone has tried using a 12 volt lead acid rechargeable battery? These are like miniature car batteries, and I'm thinking all you would need is to rig a cable with the correct power tip to the TV on one end and two leads for connecting to the two +/- terminals of the battery. The only question might be the current requirments, but I don't think that would be an issue...the other fascinating thing, would be to see just how long this would power the TV...as we all have experienced, power outages can sometimes go on for days! Someday, a company is going to come up with LONG term battery power..but until then , the 12 volt rechargeable lead acid battery (which you can get from Radio Shack) MAY be an option...
  • Haier Master
  • 12,061 Answers
You simply need a DC - AC Inverter, these can be obtained from somewhere like Radio Shack, or the like, pretty cheaply. These convert 12V DC into 115/120V AC (Some are 24V - 115/120 V) for use with your household appliances. You can get them from 100 Watts to over 1 kilowatt (!000 Watts) They can be used on almost anything at all, except things with big motors in them. Then you can simply plug the AC adapter into the inverter and you are good to go. not having to worry if your laptop is getting correct power.
Often the DC input into a laptop is between 14 Volts DC to 22 Volts DC and a high current too, up to 5 Amps. So the inverter is your best option.
Anyway you would need to use at least TWO 12 Volt batteries and then you would have to make it the exact voltage the laptop needed.. if it was say 19V then you are still going to have to find a way to drop the 24 V to 19 V, anyway so.....
Posted on Feb 03, 2010
Hi! After a power outage my Little Giant SPBS-12 backup system sounded an alarm that wouldn't quit even after power was restored (it was only off for an hour). When unplugged the louder and more...
What is the age of the unit? Those batteries don't last forever and are constantly under a small charge. When the outage happened the battery discharged and the sensing circuit was able to tell that the battery was no longer any good.
Mar 29, 2017 | Little Giant 506400 SPBS-12 Pump
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Jan 22, 2011 | Black & Decker Firestorm Slide Battery
Lost power and need to reset the timer.
Aube timers have back up battery that recharges after power resumes.
Battery should hold programming during outage.
If battery does not charge, then screen doesn't light up and programming not possible.
Aube makes several timers.
Aube timers and manuals posted at following link.
http://waterheatertimer.org/Aube-timers.html
If you have different timer, add a comment
Nov 15, 2010 | Aube Technologies Aube 7-Day Programmable...
Batery faillure
Advanced Battery Management Technology Prevents Premature Failure and Significantly Extends Battery Service Life
Batteries are the most critical component in the reliability of any UPS, but they face three fundamental challenges: All Batteries Need Charging
But extended charging significantly shortens battery life. Most batteries are charged with a trickle-charging process (a constant voltage feeding a low current to the battery). This method dries the electrolyte and corrodes the plates, reducing potential life by up to 50%.
Batteries Take Time To Recharge
Users can’t wait. During prolonged power outages, the UPS batteries will discharge and not recharge until the power returns. When there is a subsequent power failure before the batteries recharge, the computer will not have full backup time. Overly rapid charging can cause premature battery failure, so the trick is to charge at the fastest rate that is safe for the battery.
All Batteries Will Eventually Fail
The question isn’t “Will it happen?” but “When will it happen?” Because UPS batteries are valve-regulated, sealed lead acid, there has previously been no practical way to provide the user with any meaningful advance notice that batteries need to be replaced. In the past, the only way to know when the batteries were dead was when the power failed and took your computer down with it. Until now, typical UPS batteries have required replacement every two to three years.
Our exclusive ABM technology solves these UPS battery problems. It significantly increases the life of UPS batteries (see Figure 1), provides the fastest safe recharge time, and provides reliable advanced notice when the batteries need replacement. By extending battery life and virtually eliminating this major cause of surprise load crashes, we are able to offer the industry’s longest and most inclusive warranties on all products that incorporate ABM. No other manufacturer can make this statement.
ABM technology is available on Powerware 5115, 5125, 9120, 9125, 9140, 9155, 9170+, 9355, and BladeUPS UPSs.
Jul 02, 2009 | Powerware 9120 UPS System
Is there a way to drain the gas tank on a 1994 chevy corvette?
More than likely not, they dont install petcocks on fuel tanks any more, your going to have to drop the tank do drain it.
Jun 20, 2009 | 2004 Chevrolet Corvette
Shutter stuck
I wonder how good your rechargeable batteries are-even these lose their ability to recharge fully after a while. Try some non rechargeable good quality batteries in it and see if it then works properly.
Jun 18, 2009 | Canon PowerShot S2 IS Digital Camera
Sennheiser TR136 Wireless Headphones Nothing Happens
I had a similar problem - after owning them for 4+ years, no sound we coming out, and no beeps -- nothing. The lights on the charger stand were on though.
I tried buying new rechargable AAA batteries and they were NIMH (nickel metalhydride?) and still didnt work. I borrowed a friend's pair of NICM (nickel cadmium?) AAA rechargables though and the problem was solved!
So, it would seem the some of the new chargable battery types might not work in older models of this unit (which is also called the RS 130 now in the US and Cdn web sites).
Hope this helps!
Mar 29, 2008 | Sennheiser HDR 120 Consumer Headphones
Batter Life
How can I extend my digital camera’s battery life and save money?
Avoid the three main power drains in a digital camera: power cycling, unnecessary flash, and excessive LCD (liquid-crystal display) use. A camera uses power each time it initializes or shuts down, so avoid cycling the camera on and off between shots; you should only turn the camera off when you finish taking pictures.
Also, because it takes energy to use a flash, turn this component off in daylight or high-light areas. Even if your camera doesn’t fire the flash, it takes energy to keep the flash charged.
In addition, the color LCDs used on digital cameras can demand a lot of power (especially if the camera is left on for a prolonged period), so turn off the LCD and use the optical viewfinder rather than the LCD to frame the snapshot. Plus, make sure you only use the LCD sparingly to review your snapshots.
If you haven’t purchased a camera yet, choose one that uses common (low-cost) alkaline batteries rather than the more expensive lithium cells. Most cameras that operate on AA or AAA batteries also will accept rechargeable batteries, which may cost more initially but can easily pay for themselves in the long run. Of course, always refer to a camera’s manual for specific operating suggestions and precautions.
Kindly regards,
micro
Feb 28, 2008 | Samsung Digimax S630 Digital Camera
Replace the NiMh batteries. They might be bad. Could happen during power surges as you indicated you had. Let them charge up fully 14-18 hours as the book suggests.
Aug 25, 2007 | Sennheiser RS115 Wireless Headphones
Haier HLT71 7 in. Portable TV Logo
147 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
