Question about ViewSonic VA1703wb Monitor
View sonic va1703wb model no: vsa11534 serial no: qfcko70600651 is it warranty please tell me because my mointor was no display
  • Chris Hingee
    Chris Hingee May 11, 2010
    how old is the monitor?
  • 115 Answers
Follow the following steps:
To obtain warranty service, email service.us@viewsonic.com.
To obtain warranty service, the following will be required :
The original dated sales receipt (include reseller name, address, phone #, product model, product serial number, and your name if applicable)
Your name
Your company name
Your shipping address (no P.O. Boxes accepted)
The serial number of the product
A description of the problem
Regards
Ashly
Posted on Feb 03, 2010
My view sonic projector is displaying black spots.
Most Likely a bad DLP/DMD chip. If its under warranty they will fix you right up. Other wise you have to pull it apart get out the chip and then order another one for a few hundred bucks.
Dec 06, 2012 | HP "View Sonic Pjd5353 1080P Front...
I have view sonic VA1703wb lcd & the problem is screen is blinking all capacitores r ok but still this problem so any one have a solution of this problem ?
The only thing you can try is turn down the brightness, this will address some monitor issues, if this fails the inverter transformers should be suspect.
Mar 05, 2012 | Computers & Internet
Va1703 wb blinking problem
That is a sure indication of a failure in the power supply board. The problem is that Viewsonic used two different power supply boards in the va1703wb model. If you want to do the repair yourself you should be able to. If you can open the unit and send a picture of the power supply board to us at tech@ccl-la.com we would be glad to show you what parts need to be replaced to rebuild the board and get it back up and running.
Feb 15, 2012 | ViewSonic VA1703wb Monitor
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
View Sonic Monitor Serial No. QQ2081640466 Model No. VS11826 please let me know warranty of this monitor
Hi u3salkar, What the warranty covers:ViewSonic warrants its products to be free from defects in material and workmanship during the warranty period. If a product proves to be defective in material or workmanship during the warranty period, ViewSonic will, at its sole option, repair or replace the product with a similar product. Replacement Product or parts may include remanufactured or refurbished parts or components. The replacement unit will be covered by the balance of the time remaining on the customer's original limited warranty. ViewSonic provides no warranty for the third-party software included with the product or installed by the customer. Check this link ....http://www.viewsonic.com/support/warranties/limited-warranty/
Hope it may helps:
Regards; VOTIT
Dec 03, 2010 | ViewSonic VA1716w Monitor
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 19, 2010 | ViewSonic VA1703wb Monitor
How to find my hdd warranty??
If you want to know the warranty of your hdd then click the below link and fill the details and check your warranty
http://support.seagate.com/customer/warranty_validation.jsp?form=0
How To Find Model and Serial Numbers
If your drive is connected to your computer: Seagate has created a very simple tool that will tell you the serial number and the model number of any and all Seagate and Maxtor-brand drives connected in or to your computer. Use the DriveDetect.exe method to find both numbers.
You can also use SeaTools to display each number.
(See below if you have a Mac computer.)
If your drive is not connected to your computer: See the flash-based Serial Number locator tool to find your serial number and model number (and/or occasionally the serial number and the part number) on the drive label.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 01, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Nov 06, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VA1703wb Monitor Logo
149 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
